I built 2 of the same and one different today for the yard sale my back was starting to hurt then I lost my mind and made a mistake should be easy to see. Attached Images
Reply:I'm guessing the leaves would hinder getting the bottles in the first one.Millermatic 200Hobart Handler 120Victor O/A & Ramco BandsawLincoln 225 ACSnapOn AD HoodMiller XMT304/22AHypertherm Powermax 1650 G3Lincoln Idealarc DC600 w/Extreme 12 VSMiller Digital Elite "Joker"
Reply:I am going to say something is up with the support pieces on the 2nd rack there, between ring 1& 2 and 3&4?Miller Diversion 180Hobart Handler 140 (Soon to be replaced with Miller 211?)Miller Spectrum 625 Extreme
Reply:Top pic..Top set of rings..Not in line.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I'm guessing you did something by hand, maybe that one bad weld on the left I'm only kiddin Ron, could'nt help it I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Is it the support between the 3 rd and 4 th front rings on the second rack?Sent from my Kindle Fire using Tapatalk 2 Originally Posted by zapsterYou wanted to be the welder....zap
Reply:The last pic the left leaf is upside down.
Reply:Or fliped over should I say
Reply:Nice work. What did you use for the rings?.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I wasnt taking the photo straight on that is why they seem out of line, but they are straight the 4 ring rack had the cross bar misaligned, and I thought that the leaves should pointing down but hey I could be wrong. the 6 ring rack I dont think the leaves will interfear unless it is a magnum bottle, a regular should fit. I think the four ring is oriented right I looked at it the upside down way to but then I thought the grapes would face up instead of down so I turned it over. The rings come from the local metal yard in 3 different sizes, the 6 ringer is the large size, and the 4 ringer is the middle size, the cross bars are 1/8 solid that I twist myself then cut to size depending on what I need. Thanks for looking and comenting. Let me know if you see any more wrong or if I am wrong.
Reply:Do you sell these?Sent from my Kindle Fire using Tapatalk 2 Originally Posted by zapsterYou wanted to be the welder....zap
Reply:pic 2 leaf on the left is showing it's back side
Reply:Where do you find the grape vine and leaves? Looks great!
Reply:In order to have the leaves curving in to follow the lines of the rack one has to go to the back side. I bought all of the items from Patton steel in Ontario, Ca, but I think King carries them or Industrial Metal supply. Patton is a local dealer with I think 5 stores in Calif, but will ship as far as I know and all 3 companies can be found on the web.
Reply:I do make these to sell, I am having a hard time putting a price on them though I was thinking $30.00 for the 6 ringer and 35.00 to 40.00 for the 4,but time will tell. This is the 1st 3 made and out for sale today. I hope to be able to make these as well as some wind chimes and some grape trees amongst a few other things to sell on the weekends. Thanks again for the comments would like to hear more.
Reply:Looks nice. Can you tack the rings in the crotch instead of on the face ? Might dress them up.
Reply:with a longer stick out suppose I could, I will probably do a few more this week and will give it a try.
Reply:if these are designed to sit on someones fine furnature will they perhaps scratch ? Shoud they have a small pad with felt?Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:Nice Ron, but I think they are priced too cheap, especially if they are getting any type of a finish. You can always go lower on the pricing if some one is interested. Also think about removing the "stringer" that sits on top of the cast vine assembly, it looks like the rings would rest nicely on the humps of the vine and blend smootly. This woudl look perfect in a silver or copper vein powdercoat. I will send you a sample during the week if you like and we can talk more on the powdercoat oven. Might even have an extra HF style setup you could borrow and send back when you are done with it. "Anybody can talk $h!t behind a monitor, I let the quality of my work speak for itself"Lincoln Square Wave 255 and 355 Tig Lincoln 255 Power-Mig w/ spool gun Koike 5 x 10 CNC plasma Hyd-Mech DM-10 bandsaw Ineco QB-76 NC tube bender
Reply:they sure could use a felt pad on the bottom, these were the 1st 3 done and wanted to get them out for the sale. Coupe it would be hard to remove the stringer as the piece is cast aluminum and there is a small tab of metal cast in with aluminum so that it can be welded to the parent piece. I do want to finish them so that the price could be increased. That is why I was wondering if a propane smoker would generate a high enough temp to cure the powder coating? If a propane smoker would work, that would allow me to take these to the next level, by adding color to the grapes as well as a different color to the other parts. And yes I would like to see and hear more about powder coating process and borrowing the gun till enough is rolling to by my own. Thanks for the comments and would still like to hear more.Ron |
