I have a few rolls of different mig wire laying around in varying states of use and a couple were starting to get a little rusty so I had an idea to vacuum seal them with the food saver. I searched and the closest I could find was a poster who wanted to vacuum seal some 7018 rod and a few posts mentioning putting desicant packs in with wire, so I decided to give it a try although I didn't have any desicant laying around, time will tell if it works. Here's a couple pics of one of the spools I did: Attached Images
Reply:it should work, good idea..tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:maybe add some dry rice in package -- it works here in salt shakerwhen humidity get highidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Dang, never thought of that prop, I have a 10 pound bag of rice sitting in the cabinet, I'll open them up tomorrow and throw some in.
Reply:I think you're on to something! Great idea!
Reply:It works, and is nothing new! Many operating power plants (the ones I know of are all operating nuclear facilities) have gone to automated filler issue stations where they will issue all of their filler in vacuum sealed packaging, including stick electrode (except they're using the much pricier, commercial-grade vacuum packer and a specially designed 3M foil bag). A lot of R&D went into verifying their hydrogen content remained low (concerns about the fact that they were opened from the original container and not held in an oven raised eyebrows), and the results were well, well below the permissible limits. Some of the European suppliers also issue vacuum-sealed 5lbs rod packages, like the Lincoln Sahara packs. They're very handy, especially when you don't have the power to run a portable rod caddy.
Reply:I have a roll of stanles steel wire that has been around along time I would like to know if it is scrap it was out side when I found it ?
Reply:yeah,its really bad.send it to me for proper disposal.miller thunderbolt 250vlincoln square wave tig 175 prolincoln idealarc mig sp250everlast tig 210EXTeverlast power plasma 50chicago electric (hf) 130 tig/90 arcchicago electric 90 amp flux wire3 sets oxy/acet |
