Scarfing Tips?!
发表于 2021-8-31 23:23:36 | 显示全部楼层 |阅读模式
I recently saw an older welder with a scarfing tip, but the tip was half flat with the other half being the same as a normal scarfing tip. What has me is that all the scarfing tips I see are fully round with a bend. I can't seem to find his bent half shaven scarfing tip. (He had a 300 handle victor torch.)Josh
Reply:Scarfing tips are made in different configurations, some are round, some are flat on one side, some are flat on both sides. Different parts of the country call them different names too. Gouging tips, wash tips & scarfing tips.Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:Well I'm having a very hard time finding a scarfing tip flat on one side. Any and all help will be appreciated. Gizzardgutz I'm down the road from you in hot (el) Paso TX.Josh
Reply:That is a rivet washing tip, your LWS can order you one.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:+1 too what tozzi saidMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:I Googled "flat scarfing tip" & got 1 hithttp://books.google.com/books?id=WsB...20tips&f=falseOnly when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:yep a rivet buster .... oh the memories
Reply:I have a tip if you need one right away its a Victor 2-1-112 for a #315 handle. I guess what we used to call the Victor journeyman set. The torch number is worn off so I don't remember what size it is. The tip is curved and flat on both top and bottom. You might google that number and see what comes up. I have a number of round scarfing tips but this is the only flat one, used to use it to cut rivet heads off truck frames. I don't do that any more.
Reply:Thanks I found several and called victor the one i saw is not made anymore. Which led me to buy a couple scarfing tips and one rivet washing tip. Josh
GMT+8, 2025-12-27 07:40 , Processed in 0.100592 second(s), 18 queries .
