Stands Ready to Ship
发表于 2021-8-31 23:23:28 | 显示全部楼层 |阅读模式
Finally done...8 case packing tables waiting to go on the trailer.Al Attached ImagesA man is judged by what's between his legs...always ride a good horseMiller DialArc HFLincoln Classic 300DThermal Arc 181iPowermax 45Scotchman Ironworker(2) BridgeportsOkomota Surface GrinderAutoCAD 2010
Reply:Nice!-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Nice tables.(Retired) Professional firefighter, amateur everything else I try to do...Oh yeah:  Go Big Red!   (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
Reply:Interesting design, yours or built to spec?"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Not to sound ignorant Smokin,but what are they packing? I've seen something like that for wool or fleece as some might know itMagicial Magician Of Molten Metal2006 Chevy Dually Welding Truck1975 SA-200 Lincoln Red SealMiller AEAD 200-LELincoln 225 AC/DC tombstoneVictor Contractors Flaming TomahawkProfax Tig RigMore pipe fitting tools to mentionMetabo's
Reply:Very nice Al  Did you paint those or send them out? They look great."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Thanks guys.They are used to hold the cases while product is being hand packed. I'm actually not really sure how the cases are put on there...whether they are so 1 person can pack 2 cases or 2 people can pack at the same time.The design isn't mine. I went to look at a sample at the plant and get some sketches. The original was a sort of bolted together affair. These are all welded construction. There are 2 welded joints at the "riser" of the table. I would have had a second bend put on one of the plates but I wasn't sure of the exact angle so I fitted them on the frames. Press brake work gets farmed out so I couldn't trial and error the bends. Yeah Stick, I primed and painted em. Definitely the worst part of the job. You're getting a call next time for that.  I've got a place that does industrial coating and all but in a moment of stupidity figured I could do these myself.AlA man is judged by what's between his legs...always ride a good horseMiller DialArc HFLincoln Classic 300DThermal Arc 181iPowermax 45Scotchman Ironworker(2) BridgeportsOkomota Surface GrinderAutoCAD 2010
Reply:They came out AWESOME!!! But my kids can finger paint better than I could with a gun. I ALWAYS put too much on at once and then it runs!!!"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:And in Miller Blue!!!Miller Diversion 180Hobart Handler 140 (Soon to be replaced with Miller 211?)Miller Spectrum 625 Extreme
GMT+8, 2025-12-27 07:41 , Processed in 0.068553 second(s), 18 queries .
