Hydraulic Pump Motor Mounts...
发表于 2021-8-31 23:23:27 | 显示全部楼层 |阅读模式
Nice easy weld job this AM..None of the surfaces were machined flat or square it was "Just do the best you can"...Plates were just lopped off in a shear..1/2" plates at that....Don't you just love it when nothing is "The way it should be"...Just do it.So I did it.Keeping the mounting flange square with the mounting plate is the only tough part but if you know just how to tack them then all is good..These are as square as they can get..Start by tacking the ends first..then a couple on the frontside to do the pulling then add the gussets without disturbing anything then just weld away..Pics tell the story..(They did not want any weld on the inside of the flange)..Pics 1 thru 4 show the tacks..Both sides both assy's..One more post.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Pics of the complete assy's..I have a larger one to throw together tomorrow AM..I get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Nice!!
Reply:Gotta love that nice "straight" surface from the shear.....surprised they weren't twisted bad just from that. I see that dime has been around a while....stored next to your first communion dollar I take it? Nice tig work, thanks for sharing! "Anybody can talk $h!t behind a monitor, I let the quality of my work speak for itself"Lincoln Square Wave 255 and 355 Tig Lincoln 255 Power-Mig w/ spool gun Koike 5 x 10 CNC plasma Hyd-Mech DM-10 bandsaw Ineco QB-76 NC tube bender
Reply:Nice!  Pretty welds, too, as usual!  Do we expect anything different from The Zapster?But....   A hydraulic motor?  to drive a ???I can see it now... all that alignment and perfection and the shafts will be connected via a  rubber cored coupler.   Guarantees longevity of the coupler!-MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
GMT+8, 2025-12-27 07:40 , Processed in 0.070768 second(s), 18 queries .
