Metalloy 76?
发表于 2021-8-31 23:23:25 | 显示全部楼层 |阅读模式
Is Hobart Metalloy 76 good for general welding?  A guy near me is asking $50 for a 33# roll of .035.  Thanks!Sent from my C811 4G using Tapatalk
Reply:Some specs in this doc.  Note the gas mix recommended.http://www.hobartbrothers.com/downlo...CoredWires.pdf"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Thanks.  Saw another thing on it that said "75-95% argon, remainder CO2."  Do you think it would work ok with my c25?Sent from my C811 4G using Tapatalk
Reply:Originally Posted by JustmeThanks.  Saw another thing on it that said "75-95% argon, remainder CO2."  Do you think it would work ok with my c25?Sent from my C811 4G using Tapatalk
Reply:That is a very good price and works outstanding on thin sheet. Keep the solid wire for plate gauge.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Use it for anything you'd use solid wire (ER70S-6) for.  It's a metal cored wire, so it's reasonably resistant to moisture exposure.  Make certain it's not rusty...If a deal sounds too good to be true, it probably is...Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:Thanks!  I'm going to see of he still has it.  Sent from my C811 4G using Tapatalk
GMT+8, 2025-12-27 07:40 , Processed in 0.090570 second(s), 18 queries .
