Any concrete guys want to weigh in on what happened here?
Reply:Colonel Sanders cut his beard?
Reply:His lanyard doesn't match his clothes?
Reply:He will get piles from sittin on concrete like that.
Reply:[QUOTE=weldertom;3527211]They didn't use the vibrator in the form when the concrete was poured, or didn't use it enough and that's why the void was left around that threaded rod. Where I work that would NEVER pass the QA guy and would have been busted out and repoured before the steel column could be bolted down.
Reply:Get some butter folks. Larry's on a roll!
Reply:[QUOTE=Bistineau;3527311] Originally Posted by weldertomThey didn't use the vibrator in the form when the concrete was poured, or didn't use it enough and that's why the void was left around that threaded rod. Where I work that would NEVER pass the QA guy and would have been busted out and repoured before the steel column could be bolted down.
Reply:Is that a scaffolding leg that got C-mented into that footer?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:OK serious now..............................scaff post left if concrete pour
Reply:treed
Reply:Originally Posted by LarryOColonel Sanders cut his beard?
Reply:Surely when they pored it they knew it want right.
Reply:Yes, but the scaffolding was "inspected by a competent person" per regulations. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by LarryOOK serious now..............................scaff post left if concrete pour
Reply:At least they are using real scaff instead of bamboo
Reply:Originally Posted by weldertomDing!
Reply:Originally Posted by LarryOSurely when they pored it they knew it want right.
Reply:and post #10
Reply:Grout fix in that situation looks adequate
Reply:The rest of the screw jack is in the floor below.
Reply:Did he sit on the other threaded rod!?Miller trailblazer301gLincoln sa200Miller251Miller spectrum 625Victor oxy-acc2002 Chevy duramax 3500 dually 4x4
Reply:Your "threaded reinforcing" is a bit too close to the outside of concrete for most codes... I'm a bit surprised to see the base pad sitting on the floor at the bottom. What did they do pour the column base on the slab, or did they hang the scaffolding foot out over the floor cutout?.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:It would be interesting to see someone strangled by his own safety lanyard!
Reply:I know -The safety inspector is blind
Reply:I was gonna say honeycomb then I thought.........what about the sumbitch that was handin up the scaffolding!Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryanhey I got called out one day to cut off 155 scaffold stand off's that the stucco contractor just went right around and left hanging out of the finish coat. Nothing surprises me anymoreVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:You can even see the square foot on the scaffolding Jack sticking out at the floor level. Lots of things get left in concrete before a pour. I have a friend who used to work building power plants in Poland. They were removing forms after a concrete pour and found a nice rubber boot stuck in the concrete. Boots were hard to come by so they began chipping it out and found that someone was still wearing it. It was a hard life over there.
Reply:Originally Posted by duaneb55HEY NOW! Check out post #8!
Reply:Originally Posted by dubl_tSorry Duane, as per WW contest regulations, " the answer cannot be in the form of a question". But you are the 1st runner-up
Reply:Originally Posted by dubl_tSorry Duane, as per WW contest regulations, " the answer cannot be in the form of a question". But you are the 1st runner-up And Tom, when ARE you gonna bring back the chicken bowl? Shoulda never took that off the menu.......Seriously though, was this a fast-track job or just careless-ness. I had some mason buddies that worked for Baker Concrete, flying all over to build fast-track jobs. Last one they were on was the stadium in Denver.
Reply:isn't is a support of some sort? just cut it down and throw some gravel over it
Reply:Originally Posted by Power of Blueisn't is a support of some sort? just cut it down and throw some gravel over it |
