lincoln pro mig 180
发表于 2021-8-31 23:23:20 | 显示全部楼层 |阅读模式
Hey guys cant find any info on this welder that im looking for. The volts are labeled as letters. does any on have any info on that the letters represent? conversion chart would be nice to know rougly the voltage per letter. also does the wire feed speed control the amps/ current?
Reply:I've got a 180C, there should be a chart on the inside cover that tells you settings for various thickneses that you are welding.   Don't think it will tell you what voltage though.  Maybe try a search on the lincoln site. Originally Posted by stevewarrenHey guys cant find any info on this welder that im looking for. The volts are labeled as letters. does any on have any info on that the letters represent? conversion chart would be nice to know rougly the voltage per letter. also does the wire feed speed control the amps/ current?
Reply:Read this thread to understand Amps/Voltage for Mig weldinghttp://www.hobartwelders.com/weldtal...ire-Feed-SpeedLast edited by Broccoli1; 01-10-2014 at 04:43 PM.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:call lincoln they'll tell you roughly what the voltages are for each setting.
Reply:Got a meter?   It will get you as close as you need to get provided you keep your contact to work distance consistent.
GMT+8, 2025-12-27 07:30 , Processed in 0.092762 second(s), 18 queries .
