Aluminum Monitor stand
发表于 2021-8-31 23:23:17 | 显示全部楼层 |阅读模式
This is a nice stand I made for my monitor from work.  TIG welded from5052 Aluminum.  The inspiration came from a stand I saw on a iMAC. Attached Images
Reply:Nice, good lookin welds too.Welding/Fab Pics: www.UtahWeld.com
Reply:I would think the base should be wider for stability.ChadMy JeepLincoln Power Mig 215 / Magnum 300 Mig Gun / SG Spool Gun / Dual TankLincoln X-TRACTOR 1GCMiller Digital Elite
Reply:Originally Posted by chadjansI would think the base should be wider for stability.Chad
Reply:I'm so confused by the topsy-turvy pictures, I can't see straight. Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Man looks great,nice weld!
Reply:That is a very cool monitor stand.  It looks like it will also work for holding the monitor in portrait mode (vertically).  As a programmer, all my information is in long tall text.  Also, this site also looks good when you can see 3 or 4 response at a time.Nice job building just what you wanted.Miller Syncrowave 180SDLincoln WeldPak 100 with gasHandheld Milwaukee BandsawO/A Cutting Torch
GMT+8, 2025-12-27 07:40 , Processed in 0.066141 second(s), 18 queries .
