Bad Welds
发表于 2021-8-31 23:23:16 | 显示全部楼层 |阅读模式
I know some of the new guys to welding must get tired of the guys on here with experience, telling tthem they shouldn't weld on trailers, hitches and other things that might get some one hurt. Some times it's not a hitch or trailer that would be dangerous, it's something simple and seems like no big deal. Well here's why we harangue you guys.My powdercoat guy called the other day and said he had a rack he needed fixing. No big deal, I fix stuff for him all the time, stuff that they break while handling and stuff that comes in broken. Thsi time it was a rack that they hung stuff on to put in the oven. It was built by one of his hired hands for a certain thing that they do for a company on a regular basis. The hired hand told the owner that he had a little wire feed machine and he was "pretty darn good" with it. Well the first time he used it, the rack broke and the part that weighed a couple hundred pounds fell and broke. On it's way down it hit an emplyee and hurt him bad enough to need medical help.I took the whole rack apart by slamming it on my welding table. It literally fell apart. Here's a couple pictures. There wasn't much holding it together. Attached Images
Reply:People hurt from anothers stupidity. On the plus side, it now looks like you have ALL of their welding business in the future
Reply:bummer someone was injured and this is why we RANT on the right machine for the right jobidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Swing and a miss!"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:That rust will always verify the lack of fusion on a joint that is still holding. Just as in the first picture here, clearly the witness mark of rust along 80% or more of the weld could show anyone interested in inspecting the joint, that fusion was lacking. Nice post Bob!City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Can you post up what thickness the materials were? It obviously looks like no prep at all, but doubt that would have helped
Reply:Looks like someone tried to use a 125 MIG where  a 200 should have been used.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:wow thats some penetration looks like he got a full thousandth of an inch 350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:The pix show welds with what appears to be fusion on one piece and almost none on the other. Perhaps his problem is not so much the wrong machine as being blind as a bat Definitely someone who shouldn't be welding, in any case.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:another fine example of someone who thinks because they have a little canadian tire mig machine their a professional "welder" If that person was severely injured or iam sure could have been killed if hit in the head... he would have been completely liable. Alot of guys dont think that when they strike an arc on a project that their is ALOT of responsibility that goes into that project.
Reply:Will the "weldor" suffer any consequences of this? Does he know about the injury?
Reply:Better fix it right before OSHA pays them a visit.  It's surprising how often they turn up after an industrial injury.
Reply:Originally Posted by Pressure_Welderanother fine example of someone who thinks because they have a little canadian tire mig machine their a professional "welder" If that person was severely injured or iam sure could have been killed if hit in the head... he would have been completely liable. Alot of guys dont think that when they strike an arc on a project that their is ALOT of responsibility that goes into that project.
Reply:Thats not just a person that doesn't have enough pillick to do the job, he doesn't even know how to weld. We always learned to run a lap joint focusing the puddle on the bottom piece, and letting it run into and "up against" the top piece. Makes more sense than ever, now.[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Originally Posted by zapsterI simply say.."Your It!"...zap!
Reply:Originally Posted by Pressure_Welder....?
Reply:very true zap!
GMT+8, 2025-12-27 07:32 , Processed in 0.076619 second(s), 18 queries .
