Spool Gun With Weldanpower 225
发表于 2021-8-31 23:23:07 | 显示全部楼层 |阅读模式
Can anyone give me some advice on the easiest way for me to have the ability to connect a spool gun to a Weldanpower 225.  The machine has CV, and I have been told that a WC-115a will work along with a Miller Spoolmatic 30S gun.  But I was wondering, is this my only option?  Would it be easier to invest in a Miller weldergenerator and go with the WC-24?Any advice is appreciated, I'm in dyer need of a mobile spool gun rig for aluminum since I've heard the LN-7 Ln-25 option for aluminum is not the best idea.  Just a dumb farmer here looking for answers.
Reply:If you find an old spoolmatic 3 you don't need a controller as long as you have 14 pinDynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:I have both, the WC115A with a contactor with a 185 gun (I think) on the miller bobcat.  Now my newer Trailblazer runs the 30A gun through a WC24 controller, seems to have a better arc.  If you have a 14 pin plug, then I hear the spoolmatic 3 is a direct plug in, but I haven't tried it. If not, you will need not only the controller but the contactor and gas solenoid as well.
Reply:Thanks for your insite!  My Lincoln Weldanpower AC/DC 225, does not have the Miller 14 Pin plug, so I guess would need a control box with the gas solenoid, unless I can wire up my own 14 pin plug for my Lincoln.  Was just wondering if wc-115a will work flawlessly, or if there is another/better option.  Should I sell the old trusty Lincoln, and get a miller trailblazer with the wc-24? Is that better/cheaper in the long run?Lincoln Weldanpower AC/DCLincoln LN-25Miller WC-115a Miller Spoolmatic 30aCheck out my youtube TV Channel
Reply:No gas solenoid valve required as there's a manual valve integral to the Miller spoolgun.More important is the contactor to cut the weld output when you let off the trigger at the end of a weld.  Without it the arc will follow the wire back to the tip unless you pull the gun back which also pulls the shielding gas at the same time.The WC-115 / Spoolmatic 30A would work fine off the WP225 and I highly doubt selling it to buy a TB and WC-24 would be the least expensive option.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Duane, You are the best.  I'm now on the market for WC-115A with the contactor.Lincoln Weldanpower AC/DCLincoln LN-25Miller WC-115a Miller Spoolmatic 30aCheck out my youtube TV Channel
Reply:And of course you'll need the Spoolmatic 30A to go along with it.I should mention the former WC-1C (with contactor) and Spoolmatic 1 combination would do the same job as well.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I would love to go with that option, but it seems that would be a needle in the haystack.Are there any other companies that make these control boxes with spoolguns for welder/generators? I can't get over the fact that Lincoln doesn't have an "easy-to-connect" control box for all of the Welder/generator units they've put out over the past 50 years.  The LN-25 is a great "add-on", but a total bummer they don't make a spoolgun add-on.  I'm on the prowl for the WC-115a now, if anyone has one for sale, or has any advice, let me know.Miller has my business from here on out.Lincoln Weldanpower AC/DCLincoln LN-25Miller WC-115a Miller Spoolmatic 30aCheck out my youtube TV Channel
Reply:Profax has a complete line of spoolguns and controllers http://profaxlenco.com/images/Catalog/PXLN2012.pdf as does Lincoln http://www.lincolnelectric.com/asset...oled/e1222.pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Duane, wouldn't any spoolgun work with a SGC100C or something similar?  I JUST got rid of mine!!!!!! I had a trailblazer, so I upgraded o the 30A with the WC24 controller. I was mistaken when I said I had the WC115A, I had the SGA100C.  Another too early in the morning brain fart.
Reply:Goweld, ready welder will work as well no special connection needed.  I got one for sale BTW.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I found a deal on a Miller XR-5 air cooler gun, with a miller XR Feeder.  Its an older push pull model.  The guy claims to have a contactor for the box and has had it hooked to a welder generator with CV.  Was wondering if anyone had experience with this, had any luck hooking these types of wire feeds with other than Miller welder generators.  He claims the contactor has a 14-pin miller plug, which goes to the feeder, and a 115VAC recepticle which would then go the the generator for the roller motors.duane.... please help.....Lincoln Weldanpower AC/DCLincoln LN-25Miller WC-115a Miller Spoolmatic 30aCheck out my youtube TV Channel
Reply:Originally Posted by duaneb55And of course you'll need the Spoolmatic 30A to go along with it.I should mention the former WC-1C (with contactor) and Spoolmatic 1 combination would do the same job as well.
Reply:Dear Duane  I have a Weldonpower model  AC-225/DC 210 16 HP Briggs and Statton with vv/cv code 9113 serial a1088501 can I hook up a Magnum sg spool gun to it and if it's worth  the output for welding aluminum  . and how would I do it ? THANKS
Reply:You would need the Magnum SG Control Module http://www.lincolnelectric.com/asset...oln3/im398.pdf to operate the Magnum SG Spool Gun off your machine.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:You can go to HTP and buy a universal spool gun or the Profax universal.
Reply:I see that you referenced this to a Solderer I take that the maximum thickness would not very thick. What do you think the maximum thickness it would run? I already have the machine, gun, and the lines.
GMT+8, 2025-12-27 07:32 , Processed in 0.098083 second(s), 18 queries .
