I have a Miller XMT 304, I was wondering if they make a good universal spool gun? Do I need a control box for it? I have very little aluminum metal to weld.Can you hook the gas directly to the spool gun? Thanks in advance for any help.
Reply:I'd recommend a first option of a WC-24 weld controller with the Spoolmatic 30A spool gun.Option two would be a WC-115 weld controller with the same gun.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Could I just buy a cheap gun without the control box? I'm have very little to weld and don't want to spend a fortune doing it.
Reply:Typically no such thing as a "cheap" spool gun but an older Spoolmatic 3 would work as a direct connect on the XMT 304.If the requirement is only a little welding you may be $$ ahead getting a shop to do it. Where are you located? Another member may be able / willing to help you out.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I've got a spoolmatic 3 I don't use anymore,Shoot me an offer if your interested.Aaron
Reply:Would a Miller spoolmatic 100 work on my machine I just need it to do small around the house jobs not industrial .And Im only want to spend 200.00 dollars . Tks appreciate the info .
Reply:Not without an SGA 100C weld controller.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base! |
