stick welding with Dialarc
发表于 2021-8-31 23:22:57 | 显示全部楼层 |阅读模式
I recently acquired a Dialarc HF-P (serial No. HK 354326).  I don't know the age of it but it seems to be in good condition.  Until I hook up the TIG, I would like to use it as a stick.  Could someone tell me whee to connect the electroid and ground cables? Thank you.
Reply:For most rods you would hook the stinger (electrode holder), to the "+" or red terminal and the work (ground clamp), to the "-" or black terminal. If the machine is also A/C, and you want to weld A/C, then it won't matter."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Stick-man is right.  Much as it pains me to admit it, the thieving knucklehead.  On my Dialarc HF-P there's a decal on the underside of the hinged lower shield on the front face of the machine - work (that's your ground) goes on the left lug, and the electrode goes on the right lug.  You adjust polarity with the upper left throw lever.  You'll most likely be stick-welding on the reverse polarity setting.  These days we call it DCEP (Direct Current Electrode Positive).You can get a free operator's manual for your machine on the Miller website if you haven't already.
Reply:http://www.millerwelds.com/service/ownersmanuals.phphttp://www.millerwelds.com/resources...-skills/stick/
Reply:Originally Posted by tbone550Stick-man is right.  Much as it pains me to admit it, the thieving knucklehead.
Reply:Originally Posted by tbone550Stick-man is right.  Much as it pains me to admit it, the thieving knucklehead.  .
Reply:Originally Posted by Stick-manFor most rods you would hook the stinger (electrode holder), to the "+" or red terminal and the work (ground clamp), to the "-" or black terminal. If the machine is also A/C, and you want to weld A/C, then it won't matter.
GMT+8, 2025-12-27 07:32 , Processed in 0.110586 second(s), 18 queries .
