Cracked stingray block
发表于 2021-8-31 23:22:55 | 显示全部楼层 |阅读模式
A buddy of mine referred me to another shop. A stingray (62 I think) block got cracked while changing the starter. They must have lost the original short bolt, or smacked it with a hammer or something, but the outer mounting ear was cracked through on both sides. It was bad and deep enough I decided to remove it completely, and rebuild the ear from scratch. I picked up some NI-99 rod and got to work. I think around ~150A wide open, lots of short passes and lots of peening. I added about ~1/16" meat all around the bolt hole so it won't happen again (hopefully). Drilling and tapping 99% nickle isn't much fun. I didn't take pictures along the way, it was a very rushed job. At the very end, I had to make a starter support bracket, and didn't have any welders with me, so I did what I could with clamps and a hammer. Bracket is 1x.25" flat stock, which is a pain to bend by hand.Miller: 200dx, Bobcat 225, Passport, Powermax 45, Milwaukee: Dry Saw, MagDrill, grinders
Reply:Sent from my Galaxy Nexus using Tapatalk 2 Attached ImagesMiller: 200dx, Bobcat 225, Passport, Powermax 45, Milwaukee: Dry Saw, MagDrill, grinders
Reply:Nice repair.  I wouldn't worry much about it, that thing isn't stock.  Wrong color, angle plug heads, etc...TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Good job with the repair, and yea it's just another Chevy small block..Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:looks good that support bracket is way stronger then what they came with....and i cant tell you how many vettes dont even have those on the cars anymore...its almost rare to find the support bracket on a stingraybobs77vet/37ford4drEastwood digital TIG200HH190Lincoln Invertec 155sLincoln weldpak 100sears/craftsman (lincoln) 50a 240v buzz boxO/A rig Harris gaugesnexion cut 50 dxchicago electric (HF) 240v spot welder
Reply:It has  68' or newer heads on it ,hmm look like angle plug too?
GMT+8, 2025-12-27 07:40 , Processed in 0.067464 second(s), 18 queries .
