Lifting Hook on older HTP MIG 240 ?
发表于 2021-8-31 16:58:40 | 显示全部楼层 |阅读模式
Has anybody put a lifting hook on an HTP MIG 240. I am always putting my welders on and off my truck. My engine driven welders are easy. I use my bucket loader to get them on the truck. I want to make a lifting hook for my HTP 240. Got any ideas. Right now I put it in the bucket and strap it. Then get it on the truck and roll it out of the bucket. Takes too long.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:Sent you a text with my marvelous idea. Sent from my iPhone using Tapatalk ProMiller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:Just make an angle iron tray for it sit in and bolt on a bail that can be removed so the access door can be opened.MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:With all that moving around maybe you should make a cage for it to protect it.  Add all the lifting rings and tie downs you want to the cage.Century buzzbox that I learned on 40+ years ago (was Dad's)Crappy Century 110volt mig 70 amp pigeon pooper.Lincoln Idealarc TIG-300
Reply:Originally Posted by John TSent you a text with my marvelous idea. Sent from my iPhone using Tapatalk Pro
Reply:Originally Posted by walkerWhy don’t you just share your marvelous idea with the rest of us?
GMT+8, 2025-12-18 16:22 , Processed in 0.092363 second(s), 18 queries .
