i have had all the materials ready to build a 4x8 welding table.the steel is cut, have the casters and ready to weld but no top. the problem i have had is to move a 4x8 plate. so i can get a new4x8x11/16 plate delivered for $735.00 never herd of 11/16 thick ???
Reply:Probably an overrun from a mill order. I try to order decimal thickness when I can since the price from the mill is better. They usually have a 20 ton minimum to do a mill order. Someone probably didn't need the extra plate, but the cheaper price justified the extra weight.Long story short: Yes, odd thicknesses aren't that rare. No, you shouldn't buy it, since you're getting robbed at $0.80/lb.
Reply:Yeah, that sounds WAY too high. Even tho its delivered...I wouldnt do it, personally...[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:so whats a good price per/lb for plate
Reply:$0.55/lb is a number I've seen recently, but we go through a lot of plate.
Reply:.50-.55 lb. IMOMillermatic 250Lincoln 180TLincoln SP-135Miller Thunderbolt AC/DCThermal Arc 161SAirco 300 Heliwelder |
