1/2" thick black plastic
发表于 2021-8-31 23:22:40 | 显示全部楼层 |阅读模式
I hope I am not the only one of us that has ever had a need for this type of thing , but then again maybe.  I am looking for 12"x12" sheet of 1/2" thick black plastic.  Where  in the world does one find something like this.  If it makes y'all feel better is is for cushion on a metal project I am building for one of my atvs. Thanks for any insight y'all can lend.Miller BobcatHarris cutting outfitMiller spectrum 625 plasmaVariety of shopmade tools
Reply:A large plastic cutting board from Wally World would fit the bill, except for black. I use them for insulation on lead reels. They're usually white, tho.Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:McMaster Carr has the plastic you are looking for.Miller Bobcat 3 Phase,26 series gas cooled TIG torchMiller Suitcase X-Treme 12VS17 Series Tig Torch for Solar Panel Powered WeldingOxy/Acetylene Torch rigEVERLAST PowerUltra 205P
Reply:McMaster Carr, MSC, Graingers... I've got 3 different plastic suppliers in my area besides those that I've used. All of them will sell partial sheets or remnants. Delrin comes in sheets, is black , machines well and is quite durable...No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Depending on what its for Ive used scrap pieces of dump truck liner from a local shop.Millermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:Find a shoe repair shop and ask to see what they'll sell you.  For a pretty soft cushion see if they have some 55 crape.  To make a very durable but impact resistant cushion, see what they'll charge to glue lady's toplift on some 50-55 crape.
Reply:If you are as cheap as I am, find a big truck tire and cut a square out of the tread. I'd guess it would make a nice black cushion.ars sine scientia nihil est
Reply:I like rubber conveyor belts.My name's not Jim....
Reply:Old stall mat or conveyor belt.  Even some second-hand welcome mats might fit the bill.But if you want to get fancy, go get a 12"x12" piece of Neoprene at Grainger.  Or have a look at at your local hardware store.Last edited by Jack Olsen; 05-18-2011 at 01:13 AM.Jack OlsenMy garage website
Reply:There's also Online Metals: http://www.onlinemetals.com/merchant...=790&top_cat=0Miller Dynasty 200 DXBuildPro TMA52238 (38" x 22")Miller MP-10 & Jackson Nexgen EQC20 Ton Press & Swag HD Press Brake
Reply:google,Tim Beeker.
Reply:Try this place.  They have ABS, Kydex etc.  Good prices too, way cheaper than McMaster-Carr.  I'm not sure if they have 1/2" thick.  http://www.norvaplastics.com/mb
Reply:i just saw 4x8 sheets of rubber type stuff at tractor supply the other day.  i'm sure someone knows what it is and whats its used for, but i dont.
Reply:Used in horse stallsMiller MM 211Miller 375 XtremeO/A
Reply:if you go the rubber route check your local ac supply for machine mount pads they come in 12x12 and are a 3 ply design rubber cork rubber ive used 1 inch not sure how thin they go350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Originally Posted by jw3I hope I am not the only one of us that has ever had a need for this type of thing , but then again maybe.  I am looking for 12"x12" sheet of 1/2" thick black plastic.  Where  in the world does one find something like this.  If it makes y'all feel better is is for cushion on a metal project I am building for one of my atvs. Thanks for any insight y'all can lend.
Reply:Try here:http://www.usplastic.com/
Reply:Check Ebay also. I got a piece of 12x15x2 907 nylon on there for $11 awhile back. There is an outfit that apparently uses a lot of that type of stuff and sells the remnants. Just to get an idea, similar stuff from a distributor such as MC was around $150. I'd also check on there if you need a place to buy rubber, etc
Reply:go to your local glass shop and get some lexan it comes in all diff colors and thickness and you can drill it with out it cracking unlike plexi glass it will just spider on yaLincoln Pro Core 125Lincolin sp 100Miller Big 40Lincoln Idealarc SP250miller matic 212http://www.facebook.com/hdwelding?sk=wallwww.hdweldingbeds.com
Reply:EBAY EBAY EBAY cheaper than any where else I just bought 2 sheets of Lexan 1/2 the price of any supply house Miller TigMiller Mig Plasma Cam Hypertherm 100012x36 LatheBridgeport MillPress BreakShear
Reply:If you are looking for something with wear resistant qualities and double as a bearing like surface (slippery) then you will want something like delrin. Delrin comes in various colors. It is similar to a cutting board structurally speaking, but slightly different and is better for wear resistance as I mentioned.Delrin, acetyl are words to look for in your search engine.If you want cushion, delrin is NOT what you want. It is rather hard.Granthttp://jackalopefab.com/MM210Synchrowave 200DXMiller XMT350 w/60series feederMiller Bobcat 250 with SGA 100 and spoolgunHTP PlasmaFull Machine shop with everything
Reply:Thanks for the replies.   It was for a spacer between a 11 guage metal top and the roll cage on my Polaris RZR.  I took a cheap cutting board from Walmart    Surprisingly enough if lightly sanded it take rattle can black pretty well.   Thanks again menMiller BobcatHarris cutting outfitMiller spectrum 625 plasmaVariety of shopmade tools
Reply:Originally Posted by BoostinjdmI like rubber conveyor belts.
GMT+8, 2025-12-27 09:11 , Processed in 0.095405 second(s), 18 queries .
