Well--There is the problem! al tranny
发表于 2021-8-31 23:22:39 | 显示全部楼层 |阅读模式
Washed oil off, brushed on some pink cleaner (containing some hydrofloric(sp?) acid), wire brushed area.  Preheat 350, tig with 4043, postheat 350.  Tacked and in oven. I didn't bevel but instead welded both sides, on second side kept puddle just deep enough to see first weld.Preheated for 30 mins removed from oven and welded inside in 6 mins, back in oven for 20 mins and welded about 1/2 of outside in 4 mins (dealing with more corosion and ribs takes more time) , back in oven for 20 mins, weld last part of outside about 4 mins, back in oven for 30 then turn off oven and let cool. PeterEquipment:2  old paws2  eyes (that don't look so good)1  bad back
Reply:forgot pics! Attached ImagesEquipment:2  old paws2  eyes (that don't look so good)1  bad back
Reply:You get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Another awesome save Peter. Did the customer say how it broke?  Wreck?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:good as new.Buy American, or don't whine when you end up on the bread line.
Reply:Originally Posted by zapsterYou get all the fun jobs.....zap!
Reply:Originally Posted by castweldWashed oil off, brushed on some pink cleaner (containing some hydrofloric(sp?) acid), wire brushed area.  Preheat 350, tig with 4043, postheat 350.  Tacked and in oven. I didn't bevel but instead welded both sides, on second side kept puddle just deep enough to see first weld.Preheated for 30 mins removed from oven and welded inside in 6 mins, back in oven for 20 mins and welded about 1/2 of outside in 4 mins (dealing with more corosion and ribs takes more time) , back in oven for 20 mins, weld last part of outside about 4 mins, back in oven for 30 then turn off oven and let cool. Peter
Reply:Originally Posted by oxy moronyou make it sound so easy.  Forget welding, one of these days, you need to do a post about cooking.  Every one of your posts sounds like this:blah blah blah... oil... grease... blah blah blah... over... blah blah... 350 degrees... pre heat... blah blah blah... remove from oven.... cooling.. . blah blah oven.... blah blah blah re heat at 350 degrees...i fukkin' love it!
Reply:Originally Posted by castweldSorry.....blah blah blah ....more blah blah blah!Petert
Reply:Originally Posted by castweldSorry for the overload. I give the blah blah blah because that is the part people will not do, hell, the welding is the easiest part.Cooking? I can whip up a REAL Sauce Piquant. But there is no recipe. Its something that is passed from generation to generation. Besides the recipe would be more blah blah blah!Petert
Reply:It's Hydrofluoric acid or HF and be VERY CAREFUL with that stuff. HF does not burn you, it penetrates the skin seeking out calcium. It finds the calcium when it gets to your bones and that's when the trouble starts.If you EVEN THINK you got some on you, seek medical attention immediately. They have to give injections to keep the stuff from eating up your bones.HF is used a lot in semiconductor mfg., along with just about every other major acid out there. We had guys get some on them and they were always sent to the ER immediately for treatment.Aside from that major precaution... great save on that tranny case!PapaLincoln Idealarc 250 (circa 1962)Lincoln Weldpak 155 w/Mig KitLincoln Squarewave TIG 175
Reply:Originally Posted by Oldiron2Looks like with being very busy, with all the heat, and being buried by 'blah's, you've just gotten plum"Perert" (sic) out!
Reply:very nice repair as always castweldMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Originally Posted by castweldThanks, I thought HF stood for Harbor Freight!
Reply:Brand name of cleaner please good sir?
Reply:Originally Posted by WeldingWookievery nice repair as always castweld
Reply:Originally Posted by farmallBrand name of cleaner please good sir?
GMT+8, 2025-12-27 09:10 , Processed in 0.109530 second(s), 18 queries .
