start to a new 62 yrd dipper door
发表于 2021-8-31 23:22:39 | 显示全部楼层 |阅读模式
Building a dipper door from the ground up. Only about a week of work into it so far. A few shots of the beams and parts to the bolster box. Also one of the ears. Last pic is parts being tacked to the back of the face. I will keep posting pics as we move along. Its all  1 1/2 and 2 inch plate so far beveled for 100% penetration. Attached Images
Reply:Man I miss heavy equipmentSIN CITY METAL WORKSvisit my YouTube channel https://www.youtube.com/user/devvon
Reply:Originally Posted by wd40prerunnerMan I miss heavy equipment
Reply:Holy Heavy Metal, Batman!Member, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Holy crap!www.thefusionsolution.com
Reply:0k small update. pics are of most of the parts tacked into place. then the welding begins. I got a few shots of my welding ..... nothing special. Hope to have this completed in another week as work is pilling up. comments or suggestions are welcome. i like to get new ideas on how to fabricate things. Attached Images
Reply:You know someone is going to say that should be stick welded cause the wire just won't burn in like the old buss box.Millermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:Originally Posted by farmshopYou know someone is going to say that should be stick welded cause the wire just won't burn in like the old buss box.
Reply:Originally Posted by MikeGyverThat's dual shield wire, it's made for stuff like this, stick would take forfreakingever.
Reply:yes it is mostly all dual shield wire. its not in a shop just a three sided building on wheels so if the wind picks up out comes the NR233.Mick thanks for the kind words. As for serious stuff i am not sure we want anything more. We are running supper lean on help....So if anyone wants to come sling some wire in the desert heat give a shout.I will keep pics coming .. thanks for looking
GMT+8, 2025-12-27 09:11 , Processed in 0.097229 second(s), 18 queries .
