Sprayer for the lawn mower.
发表于 2021-8-31 23:22:38 | 显示全部楼层 |阅读模式
I got sick of walking around the fields and trees so i made this up real fast this morning to spray around-up. Pump i got from HF for $37 and some fits, hose and sprayer from TSC for about $30 and the tank was free from a car wash i do maintenance at. Sorry no good weld pics tho   But over all it works good!
Reply:How many gallons does the tank hold? At a little over 7lbs/gallon, I would imagine that the frame takes some stress.Not to nit pick, but it seems that the frame already has a slight bow to it, I would be concerned with eventual permanent distortion from abuse by the terrain. Just something to think about.
Reply:Nice! I have been thinking of  something like that How is the pump shut off and on and does the pump have a bypass when running and not spraying?I always tried to work with the oldest hand on the job to gain knowlege but now I can't find any.
Reply:Originally Posted by smokin_dodgeHow many gallons does the tank hold? At a little over 7lbs/gallon, I would imagine that the frame takes some stress.Not to nit pick, but it seems that the frame already has a slight bow to it, I would be concerned with eventual permanent distortion from abuse by the terrain. Just something to think about.
Reply:Originally Posted by digrNice! I have been thinking of  something like that How is the pump shut off and on and does the pump have a bypass when running and not spraying?
GMT+8, 2025-12-27 09:11 , Processed in 0.070499 second(s), 18 queries .
