help me please
发表于 2021-8-31 23:22:33 | 显示全部楼层 |阅读模式
i been going to a high school voca for welding, i know how to stick weld pretty good i got certifited last year at a comp. for 7018 3/4 3g and 4g, i know how to mig weld but im just not to into it, i just started to play around with the tig welder im not going to brag about im pretty good at welding stanless steel and low carbon steel, my question that im getting to is how do i go about getting a tig welding job that pays good i would love a tig pipe welding job cause i love the challange , what kind of unions are there for tig pipe, ho much does it pay, is stick welding a better path than tig welding, and what is a common machine that most tig use. lot of questions but i cant find anything or google or bing and not to people in my area that i know , know the questions that i ask
Reply:I can't really answer any of your questions other than to say it depends on the particular region.  I will suggest you learn all processes and become proficient in all of them to be as "marketable" as you can be.  Even any process(es) that you might not be "too into". MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:keystoneIce , lol , thats like the cheapest beer with the highest alcohol% around here. it's like $1.19 a 24ouncer .  i know   ima go crack open a 24oz Busch , just for seein your name lol        thermal arc 252i  -  millermatic 350P -   miller XMT, cp300ts, 30a 22a feeders, buttload of other millers, handfull of lincolns, couple of esabs  -   Hypertherm 1250 G3
Reply:Hey, don't be knockin the Keystone.Good luck on the tigging. Get started on aluminum and become the Zen master of purging, then we can talk.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:do everything! do not spend your time in high school focusing on one process milk your teacher for every ounce of knowledge he has
Reply:boilermakers do a lot of tig welding tubes  i am a boilermaker tube welder and some plants we tig the whole tube out by buddy welding and sometimes we just do a tig root and stick the rest. it pays good and its fun you should check out your local boilermakers union.
GMT+8, 2025-12-27 11:09 , Processed in 0.169387 second(s), 18 queries .
