6010 vertical
发表于 2021-8-31 23:22:33 | 显示全部楼层 |阅读模式
hello i am new to the forum,i am running some 5/32 and 1/8 6010 vertical and i have been using the "inverted T" technique but my beads are just a little too wide   i was wondering if anybody could suggest other ways that they run 6010 vertically? any response would be appreciated thanks,Aaron
Reply:I'm not a 6010 hand at all, I need all the help I can get, so I run a flat bottom U. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:i make circles(once you add travel to a circle i guess its a helix)and run downhill..the faster and tighter i make the circles the smoother the bead looks Attached Images
Reply:thanks for the advice guys, CEP when you make the flat bottom u    do you whip in and out of the puddle? do you do this for your fill passes as well on that pipe? and weldbead    i do the same thing for downhill  i was just wondering what you do for uphill?thank you guys so much for replying the advice really helpsaaron
Reply:No, no whip! For vertical up on plate, and my hot pass on pipe I run the flat bottom U. For the cover pass on pipe I run 6010 just like 7018. Hold / pause on the sides, move across the middle fast.Remember now, arc length is critical! You control the fluidity of the puddle with the arc length.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:can send anymore pictures CEP i am still having trouble, i know how to run the weave like a 7018 but everytime i run the flat bottom u it seems to be too large for a stringer    are 6010 stringers supposed to be way bigger than 7018 vertical stringers?thanks a tonAaron
Reply:Originally Posted by aaronolsoneverytime i run the flat bottom u it seems to be too large for a stringer
Reply:Here's a picture of a hot pass on 2 1/2 inch pipe 5-G. I used the flat bottom U pattern, with 1/8 inch 6010. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:ok thanks ill try that    so basically pause on the sides of the flat bottom u pattern right? i know this must be annoying me asking all these questions but i really appreciate it thank you very muchAaron
Reply:ill try the j pattern as well thanks Aaron
Reply:Originally Posted by aaronolson i know this must be annoying me asking all these questions
Reply:ha i know man i hate trying to say whats in my head on this stupid keyboard. ill go try it and let you know how it goesthanks againAaron
GMT+8, 2025-12-27 09:11 , Processed in 0.098571 second(s), 18 queries .
