Splicing power cable.
发表于 2021-8-31 23:22:27 | 显示全部楼层 |阅读模式
What is the best way to splice two power cables together? I have a Century Buz Box with about 6ft of 6/3 power cable, I just picked up about 12 more ft of 6/3 SO for really cheap and would like to splice the the two together. I was thinking about using split bolts and heat shrink and putting the splice in a juction box or something to act as strain relief but am open to other ideas.
Reply:I added some cable to mine cracker box by just butt splicing the indivdual conductors and taping with 3M 33 tape.  Stager the splices so the cable thickness won't be so much thicker where the splice it.
Reply:Split nuts and heat shrink tubing or electrical tape will work, but not as sanitary/professional looking as cable connectors. Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:Just buy the set of plug and cord receptacle. That'll give you a 12' extension cord. No splicing. No damaging your existing welder.Be wary of The Numbers: Figures don't lie,. but liars can figure.Welders:2008 Lincoln 140 GMAW&FCAW2012 HF 165 'toy' GTAW&SMAW1970's Cobbled together O/A
Reply:Originally Posted by WyoRoySplit nuts and heat shrink tubing or electrical tape will work, but not as sanitary/professional looking as cable connectors. [img]
Reply:Originally Posted by npg170I may just wind up replacing the short cord with the longer one and calling it a day.
Reply:You can go to an electrical supply shop and get butt connecters for 4 and 6 gauge stranded conductors.Use those with good heat shrink wrap and a lot of electrical tape and you will be all set.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:Twist the ends together and soak solder into the wires and put heat shrink over it. I have one that is done like that and it is 20 years old and never been a problem.
Reply:I concur, i solder everything i can. Heat shrink right over the top and they will last forever.Fireman BillHH 210 MVPMM 211 Spoolmate 100Lotas LTP5000D PlasmaOxy/Accet (Victor)Wards AC/DC buzz box30 ton old hyd pressA few brand name toolsA bunch of cheap toolsA wife to worry me and4 dogs to supervise me
Reply:Originally Posted by Fireman BillI concur, i solder everything i can. Heat shrink right over the top and they will last forever.
Reply:a small piece of copper pipe makes a good inline crimp.2 1/2 inches or so, go in halfway from each end,till the cables touch, use a chisel and hammer to strike in crimps, friction tape then cover with scotch 33 plus..
Reply:Home depot sells. Little aluminum tubes with set screws.  Slide wire in tighten tubes.   Heat shrink over top and for strain relief could put in an electrical box.    Lots of good ideas here.  And all would work
Reply:Originally Posted by large-humanHome depot sells. Little aluminum tubes with set screws.  Slide wire in tighten tubes.   Heat shrink over top and for strain relief could put in an electrical box.    Lots of good ideas here.  And all would work
Reply:i thought you were talking about welding cable,,,a westinghouse splice is the best for power cable.
Reply:Thanks for all the suggestions guys, I'll just twist and solder and the heat shrink all of it and call it a day.
GMT+8, 2025-12-27 09:31 , Processed in 0.094102 second(s), 18 queries .
