Gritty look to my welds (Alum)
发表于 2021-8-31 23:22:13 | 显示全部楼层 |阅读模式
I've been slowly teaching myself to TIG aluminum as I think I have MS and SS down. Only issue I am having is this gritty look to my welds. Not sure if its contamination or what? Im using acetone to clean the metal and filler, and a dedicated SS brush. Welder is a Miller Syncrowave 180SD, 100% argon @ 15cfh, green 3/32 tungsten. My filler rod is a few years old, but was kept dry in a tube the entire time. It happens at any balance setting, and sometimes it doesnt happen at all and I get shiny weld beads.Any thoughts?TIA
Reply:Forgot to mention, base metal was 1/8" 6061 flat stock I picked up at Fastenal, filler was 1/8" 4043
Reply:Originally Posted by turbodls1taForgot to mention, base metal was 1/8" 6061 flat stock I picked up at Fastenal, filler was 1/8" 4043
Reply:Usually when I see this its not from welding too hot, its from moving too slow
GMT+8, 2025-12-27 09:31 , Processed in 0.092829 second(s), 18 queries .
