LOWE'S 12 pd spls of L 56 on clearance
发表于 2021-8-31 23:22:09 | 显示全部楼层 |阅读模式
Stopped by Lowe's in Kenosha, Wisconsin. Had 12  1/2  pound spools of L-56  .030 on clearance for $34.88. They honored the 14% off Menards bag coupon. Each spool was around $ 29.00.   Bought the last two .
Reply:Good ole Blowze.Buenas tardes Don Douglas. Si tengo rollos de L-56 en 5 kilos En 0.25 (0.6) te cuesta 12500 mas imp ventas. DAT B $25.00En 0.30  (0.8)  9500 mas imp ventas .DAT B $19Para la opción del piso te ofrezco unas cortinas de 6 x 6” Wilson (1.83 metros ) cada una te cuesta 32000 . Son especiales para las chispas .DAT B 6x6 Wilson vermiculite welding blanket. $64.00Cualquier consulta con gusto.There's a 26% import tariff here on all things welding(the machines themselves are 14%), plus the boat ride. Gawd Bless Blowezzz !I have a date with an aviary. The tubing dances with the .023. The top and bottom chit pans(seams and handles) and wheel mounting plates dance with the .030.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:CantidadDescripcion del ArticuloP. unitarioTotal1CODO HN SOLDABLE CED 403/4'' X 90₡230.00₡230.001CODO HN SOLDABLE CED 403/4'' X 45₡210.00₡210.001TEE HN CED 40 SOLDABLE3/4''₡750.00₡750.001TAPA HN CED 40 SOLD.3/4''₡250.00₡250.00SUB-TOTAL₡1,440.00I.V₡187.00TOTAL.₡1,627.00FECHA:1/8/2014TELCLIENTEOASIS TUCANES JARDIN BOTANICO TILARANFAXATENCIÓNDOUGLASVictoria Navarro#[email protected] weldable pipe fittings.It gets better.Check out the owner. Mechanical engineer chick.http://www.linkedin.com/profile/view...cmpt%3AprimaryLast edited by Burpee; 01-21-2014 at 10:25 PM.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:^ Dah hell?
Reply:Originally Posted by TSCGG13^ Dah hell?
Reply:Burpee, how much you had to drink there bro?TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:You guyz.You'll never understand until you see it from the outside.Here's another pic of Victoria.I can't make this up..........It just IS Here. Go look.http://www.linkedin.com/profile/view...cmpt%3AprimaryBubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:BuuuuuuuurpBubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:No. REALLY !Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Man..............Here.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:True FreedomBubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:This is why you do not do drugs !  I think you maybe on the wrong post.
Reply:Originally Posted by BD1This is why you do not do drugs !  I think you maybe on the wrong post.
GMT+8, 2025-12-27 11:21 , Processed in 0.107146 second(s), 18 queries .
