.045 sold wire with an ln 25, ever done it?
发表于 2021-8-31 23:22:09 | 显示全部楼层 |阅读模式
friend of mine just gave me two big spools of 045 solid wire..ever use such a thing in an ln 25?,i'd like to use it up if i can..argon?
Reply:C25 or CO2 if it's ER70S (mild steel) wire.The LN-25 will handle it with ease.  A lot of .045 goes thru LN-25s every day.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Yup, it is done everyday.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Nope, I'll pm you my address and you can send it to me to dispose of
Reply:ok great,good money saver,i'll rig it up tomorrow! dcep right?
Reply:DCRP 22-26 Volts unless you have a CC only machine then turn it up and hold on.....LOLDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:ok,i'll set it up tomorrow..let you all see some results..
Reply:I guess it depends on your power source, but I doubt you'll notice any difference between an LN-25, and any other dedicated Mig machine. Here is some .045” L-56 vertical up ran with an LN-25. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:is that with solid wire or flux core?
Reply:Yes Lincoln L-56 Mig wire, (solid wire). With C-25 gas.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Drive roll kit is about $75, so you need to balance that against the economy of the wire. I also stopped using the larger spools in my LN-25, in favor of the 10 pounders, as carrying the feeder around with the big ones gets old fast.
Reply:Originally Posted by walkerDrive roll kit is about $75, so you need to balance that against the economy of the wire. I also stopped using the larger spools in my LN-25, in favor of the 10 pounders, as carrying the feeder around with the big ones gets old fast.
Reply:dang it! don't have the proper gun set up,need to adapt one of my profax whips to the ln 25,,,back to stick welding for today anyway!!
Reply:Originally Posted by iron mikedang it! don't have the proper gun set up,need to adapt one of my profax whips to the ln 25,,,back to stick welding for today anyway!!
Reply:how much?
GMT+8, 2025-12-27 11:20 , Processed in 0.252369 second(s), 18 queries .
