Cheap pneumatic cart tires
发表于 2021-8-31 23:22:06 | 显示全部楼层 |阅读模式
Tractor supply has bearing and sleeve-type pneumatic cart tires and rims (China of course) for 5 bucks apiece. anyone looking for a cheap solution for tires.Bearings need lubed and are crappy, but should be good enough(4.10/3.50 size) That and a 5/8 5 inch bolt welded to the frame supplied my all-terrain needs.
GMT+8, 2025-12-27 09:31 , Processed in 0.097958 second(s), 18 queries .
