"The Second Symbol"
发表于 2021-8-31 23:22:04 | 显示全部楼层 |阅读模式
I was commissioned last week (@ the art fair) 2 render a design into this 6"x6" sculpture in stainless steel. Used tig process thru-out. Delivered finished piece 2 client yesterday. Attached Images
Reply:Hey  grumpycricket that looks neat. You have a tallent for sure. Good luckFox speedAnd happy welding Sent from my Desire HD using Tapatalk 2
Reply:Grumpy, your stuff is amazing.  Said it before on other sites, but I tend to repeat myself, LOL.
Reply:Thanx, glock & Oldendum.
Reply:bitchin' finish... tell us more about the finish
Reply:The actual symbol is stainless shaped with tig, with drip by drip build up & "shaping" with the heat of the tig. I purposely left it "lumpy", cleaned it up with scotch brite discs, then polished it 2 a mirror finish. Then into a 900*f oven for about 3 hrs. Also hit it with a rosebud, oven time only tanned it,& I wanted some blue & violet hilites, After cooling, sprayed it with Rustoleum enamel clearcoat. The client wanted the symbol 2 look like water I don't think I succeeded, but she liked it!
Reply:Originally Posted by grumpycricketThe actual symbol is stainless shaped with tig, with drip by drip build up & "shaping" with the heat of the tig.
GMT+8, 2025-12-27 11:30 , Processed in 0.092818 second(s), 18 queries .
