Another first beads photo
发表于 2021-8-31 23:22:04 | 显示全部楼层 |阅读模式
I enrolled in a "Continuing Education" welding class at the local tech school.  I have a Lincoln 140 MIG (and have produced plenty of pigeon poo getting started) but I have no stick machine so I figured this would be a way to gain stick experiance and professional coaching.  So my first ever first stick beads are pictured below.8 gauge coupon, 6013 1/8, Thermal Arc 400 MST, 82 Amps (as set by instructor.)May the flogging commence!    - Mondo Attached ImagesMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Four hours since posting, 112 views, not a single comment.  Not even so much as a "your beads stink."    Can I delete this mess?Member, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:From the top one, I would have thought 6010.  It is interesting that they have you working on such small pieces...Not too bad for a start, though.  I especially enjoy the flogging comment.
Reply:Originally Posted by MondoFour hours since posting, 112 views, not a single comment.  Not even so much as a "your beads stink."    Can I delete this mess?
Reply:Bottom one, right side is a bit cold & has some undercut it looks like.  Although that might be the camera angle too.Slow down on the right side, watch the puddle & let it fill, then move.  Nice & steady wins the race.Top one looks ok.  Started out ok on the left, then it looks like you sped up a bit.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:The beginning of the 1st pict looks ok, but then it looks like you either sped up, or started to  hold a longer arc. The 2nd pict looks cold. Everything else being equal, I'd have to say maybe you held the arc too tight on that one possibly.6013 will tell you when you have all the settings, speed and positions right. The slag will just curl up behind you or fall of in big chunks. If you have a lot of chipping to do, it means something wasn't right.I'm also a bit surprised they are using such small and thin coupons for stick. We us 3/8" for all the stick work..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I'd also recommend using a bigger cupon...even if it ain't 3/8 thick  a bit wider plate will take the heat much better.  My students  use 1/8 6013's on DCEP.  We run around 105 amps.
Reply:Looks like you have the right idea. Now practice till you see the puddle in your sleep. Good luck.
Reply:Thanks, guys!  That's the commentary I was hoping for!  Now I have something I can 'take home' so to speak.  Small coupons, yes. Stingy, I think.  I have no idea what the "lab fees" are, they build that into the price of the course so you don't know.  We can run another bead along side the first one but that usualy burns off the edge.  I flip 'em over and run a string on the other side.  The first bead bends the coupon, the second one on the flip side flattens it again.Right on the analysis....   I'm still trying to hold a steady arc - same length.  It gets long and then I dive in too deep over correcting.  Practice Practice Practice is all I need there.Had only one in which the slag peeled off by itself, as I recall.  Not in one long worm, but in sections.  I'll try to get that effect next class on Tuesday.- MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Good luck bro.  Keep workin and Watch That Puddle!
Reply:when my dog saw that he puked...hey ray hows it goin?you can butt joint the coupons together ..
Reply:The welding class finished up a month ago.  I still haven't mastered the art of consistency in appearance so I have been reluctant to post.  I could post some of my better welds, I suppose.My main project was to build a pallet fork attachment for a compact tractor.  Done and works well!   The tractor has a universal skid-steer type mount on the loader frame so that is what I matched it to.  The forks are 2 x 4 x 1/4 HSS (Hollow Structural Steel – aka rectangular tubing as we all know it.)   To avoid having gussets in the corners of the forks I made a miter joint and reinforced it on the bottom with a piece of 3/8 x 4 HR Flat. 9” long with a 90° bend at 6” then added a 6" x 6" L cut from 1/4” plate on each side.  I am sure the forks are not as strong as a real fork-lift tine (forged high-strength and tempered steel), but they can lift far more that the hydraulics of the tractor for which it was made.The forks are hung from standard black pipe.  Cheaper (and probably weaker) than DOM tubing, but clearly strong enough for the need.  I used a die grinder to clean the root of the welded seam out of the inside of the stubs of pipe that are welded to the top of the forks.  This permits them to easily slide and rotate on the long pipe from which they hung.I don’t have any close-ups, but here’s some pics showing it at work on the farm.- Mondo Attached ImagesMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Please post some more of your practice beads. If I can catch a break I want to get into our local tech class this July. I'm curious, how many hours was your class? Ours is 9 hours a week for 5 or 6 weeks. Right now my better beads resemble your first ones here.
Reply:http://www.esabna.com/us/en/educatio...inginspection/
Reply:Originally Posted by TomHPlease post some more of your practice beads. If I can catch a break I want to get into our local tech class this July. I'm curious, how many hours was your class? Ours is 9 hours a week for 5 or 6 weeks. Right now my better beads resemble your first ones here.
Reply:Thanks Mondo, sounds like a good time. This class I'm looking at is one of three just for stick. As the description doesn't say much more than "beginner", then there is intermediate and advanced. I'm assuming these are career grade classes as there is one class labeled for the hobbyist. Sounds much like the one you took. Not sure if I'm looking for a career, but ain't gonna rule out either. As a carpenter /framer I've taken a real beating these past four years.
Reply:Finally, photos of the finished product. Fits a 3400 Kubota.Look ma!  No gussets!The forks are 4x2x1/4 HSS cut and jointed on 45° (miter) which is then reinforced with 2" wide x 1/4" L plate on the sides with a 3/8 x 4 x6 bent at 3" on the bottom (not pictured - I know, I should have photographed it from the bottom.)Basic frame is 1x2x1/8 HSS  Flat plates on end and mount are 1/4", the horizontal stiffeners in the middle, top and bottom are both 3/8" HR flats.  Next are some pics of the basic frame partially assembled. Attached ImagesMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Basic Frame. Attached ImagesMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
GMT+8, 2025-12-27 13:00 , Processed in 0.153583 second(s), 18 queries .
