Padlock & Chain protector ??
发表于 2021-8-31 23:22:02 | 显示全部楼层 |阅读模式
Anybody here ever made a box or such for a padlock and chainso that the padlock is enclosed somehow so that a bolt cutter cannot access the lock loop ?MM 180
Reply:This is the best lock that I know of for cut and pry resistance. Charleyhttp://www.1st-in-padlocks.com/187ka...facturers_id=5Miller MM252Miller Bobcat 225NTMiller DialArc HF / DIY Cooler2 Victor O/A TorchsetsMilwaukee 8" Metal SawMilwaukee Dry Cut "Chop" Saw 5 Ton Wallace Gantry Various Grinders, Benders, etc.
Reply:Rectangular tube and use the lock to "pin" the chain from being pulled out of a "keyhole" of sorts?
Reply:lennyk, I made one a few years back.  As I recall, I used a rectangle of 1/4 or 3/8 inch thick steel that fit inside the lock loop but was groved on the curved edge so the lock loop sat down in the steel block.  I might be able to supply a picture later.Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Originally Posted by Rick V . . .I used a rectangle of 1/4 or 3/8 inch thick steel that fit inside the lock loop but was groved on the curved edge so the lock loop sat down in the steel block.
GMT+8, 2025-12-27 11:28 , Processed in 0.101446 second(s), 18 queries .
