Got my first job
发表于 2021-8-31 23:21:59 | 显示全部楼层 |阅读模式
my dad is a contractor and is replacing a 2nd story floor and needs two holes put in the I beams every 16 inches im only getting $10 an hour and my gas paid for but its a start,i dropped my torch off yesterday and cant wait to get started
Reply:Good luck.If the beams are already installed, don't burn the house down.
Reply:Sounds like fun. I remember working in construction and building homes i was the only welder/cutter on the crew that knew what he was doing so those cutting and welding jobs were a blast. And he some helpful tips for you. Get some of those big fire blankets the bigger size ones so you can blow the sparks in to the blanket and not burn the studs or the PVC piping or the electric. And move all the plastic tool cases and nail boxes so they don't melt. And if your working with your crew or the other trades give them a good warning so they knew when you'll be cutting. Enjoy the job and good luck cutting .Millermatic 211 with mvp plugs miller titanium series welding helmetstihl chain saws 8 ft welding table
Reply:Congrats.  Take some burn pics for us.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Ya just might want to have a fire ext with you as well in case a spark ends up where you least expect it to.
Reply:Originally Posted by JPweldingmy dad is a contractor and is replacing a 2nd story floor and needs two holes put in the I beams every 16 inches im only getting $10 an hour and my gas paid for but its a start,i dropped my torch off yesterday and cant wait to get started
Reply:Mag drill. My thoughts exactlyMiller diversion 165Miller mig 211Hypertherm pm 30Milwaukee 6230 14 inch chop sawMd 45 mag drill (RIP; fell on its head)New MD 45! Thanks to the esposa!Finally got an O/A setup
Reply:Is this new construction or tear out.  Are you burning the holes in to the flange or the web of the beams.  I know you are just doing what you are told but you just can't go cutting holes in I-beams and expect them to hold as designed.Great that you are working in a trade and get to work with your dad.  Follow the advice of the others and don't burn anything down.DanLast edited by DanD78; 06-20-2012 at 08:24 AM.
Reply:Thanks for all the support guys,i cut 2 holes on an 8 inch flange of the beam about 3/8" thick every 4 feet,we are tearing out an old floor in a a barn and rebuilding it the holes where just so we could lag a plate to the top of the beam for something to nail to,and i do have a fire blanket witch i used but it was a pain with only one like 6X8 and i had to move it all the time but the job is done and everything went smoothly and i made some money
Reply:HAHAHAHA, Good for you JPwelding, really is a good feeling making some money using your own skills,the pay may not be that big yet but its a start, good luck and enjoy what you like doing best.
GMT+8, 2025-12-27 11:38 , Processed in 0.071857 second(s), 18 queries .
