Miller 12vs suitcase Lead problems need LINER!?
发表于 2021-8-31 23:21:57 | 显示全部楼层 |阅读模式
Just got a used miller 12vs suitcase for my miller bobcat 225. I used it to weld a few parts. I had some binding and bird nesting in the case. I think this is caused by the liner. I want to get some new .045 tips and a liner.  I think its is pretty basic to change not very complicated. I have a 13 foot miller lead. I looked on ebay i see bernard liners and miller liners. i think they are the same. I do not see 13 foot? I only see 15ft. Can i shorten at 15foot to a 13 foot or what is the correct part number
Reply:Yes you can shorten a liner. Be sure to read the instructions as to exactly how to instal the liner, so you don't accidently cut it too short.http://weldingweb.com/vbb/showthread.php?t=35116 Originally Posted by lotechmanI am running into a lot of incorrectly installed liners.  It seems that people fail read the instructions when installing the liners.  Liners are supposed to be slightly too long so that when you install the diffuser you have to push against the liner.    If you trim the liner to gun length what happens is there is a small gap between liner and the diffuser which encourages wire jams and poor feeding.  In one place I even was "instructed" by the head machinist on how to install liners.  After the little lecture I understood why they had feed problems and were always replacing liners thinking that the liner was bad.  One man, ten wire feed machines and ten problems.  If you have never installed a liner, don't open the package and throw away the instructions.  On some Lincoln equipment they even give you a little gauge.  It must be important if they include a little extra piece of metal.  End of rant.
Reply:Also do not use a cut off tool. it leaves a sharp edge fro the wire to scrape across.Use a good set of side cutters, split the coils and then cut it off. If the end sticks out, cut or grind it down. You need to turn on the diffuser with out it catching. Liners are different, so you have to get the correct liner for your make and model gun. Best way is to take it in to your LWS for your first new liner. save the package with the part number and you can buy the next one anywhere. If you ask nicely they may even show you how to install it.
Reply:I personally like a small pair of cable cutters since they cut in a circle and leave a nice edge for the wire.
GMT+8, 2025-12-27 11:28 , Processed in 0.154940 second(s), 18 queries .
