Is a full 150 size bottle of c25 worth $150?
发表于 2021-8-31 23:21:53 | 显示全部楼层 |阅读模式
Assuming its user owned and refillable/in good shape? Guy selling it says 4ft tall it maybe something other than an Airgas 150 but its close.
Reply:As long as my supply place will fill the brand, I would buy it at that price no problem.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:^^^ what he saidGravelThe difference between theory and practice is that in theory there is no difference.
Reply:There is only one place here in town and its a Praxair which is the last place it was filled. I might have to snag it.
Reply:Just make sure the collar is blank which means it a "customer owned" bottle and not a rental.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Just remembered someone here recommended meeting where you get them filled - if they say they'll fill/exchange it later - buy it That way you won't get stuck with one you can't fill.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Good idea, Dave!GravelThe difference between theory and practice is that in theory there is no difference.
Reply:To buy a 150 buy me from supplier is $ 225.00 filled . Prices vary by location and supplier. I would check the test date too. Some suppliers may charge more to have it retested . I would check name on neck and call supplier to see if they will exchange it.
Reply:I would check the hydrostatic testing date to see if it is still within time. I would also look for a star in front of the date. That means that it's a ten year period from the testing date. If the date is good, that's a bargain. If not, it will cost extra for a test but that wouldn't necessarily be a deal breaker.Miller Millermatic 252Miller Syncrowave 200Liincoln AC-DC 225Victor O-A Set
GMT+8, 2025-12-27 11:38 , Processed in 0.104883 second(s), 18 queries .
