Is a trailblazer 301g a good welder?
发表于 2021-8-31 23:21:52 | 显示全部楼层 |阅读模式
I found an 02 trailblazer 301g on craigslist. Came from a diesel shop, had the oil changed every 35hrs and the filter every 70. It has 530 hours on it and its listed for 1800. Never ran anything more then a grinder and 5/32 7018Sent from my C811 4G using Tapatalk
Reply:I love mine, its an 04, 3800.00.  I love the way it tig's aluminum.
Reply:so if i wanted to i could hook up a helium bottle to my scratch start, or get a 14 pin foot pedal i could weld aluminum?
Reply:The only thing youll be scrathing is your head looking for a bottle of helium these days. Straight argon little buddy!I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:For 1800 buy it, I bought mine new and love it, Aside from my little board malfunction I havent had any major problems. If you get it, pull the tin and blow the boards off and everything else thats in there.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Are the 301's different from the 302's ?Because I have lift start tig with auto stop or auto crater fill modes..Which is way better than scratch start particularly when doing thin materialSent from my SPH-D700 using Tapatalk 2Backed my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:I just got mine out of the shop.  Went to use it a couple of weeks ago and it acted like it was full blast on the amps and would not turn down.  Ended up replacing a couple of components on the voltage control board.  Cost was around $570.  Other than that love how it welds.  There are other threads on 301G's if you do a search.  I would get another if needed.Dan
Reply:well guys this 15 year old is gonna suck it up and buy it. going to the bank in the morning and getting out 1800 from the ol savings account. the seller is not including leads though. anybody got a good source for welding leads that can push 300 amps. id like to have about 75ft on the work and stinger.
Reply:Originally Posted by swampwelder13well guys this 15 year old is gonna suck it up and buy it. going to the bank in the morning and getting out 1800 from the ol savings account. the seller is not including leads though. anybody got a good source for welding leads that can push 300 amps. id like to have about 75ft on the work and stinger.
Reply:Originally Posted by SquirmyPugBe sure you have some leads to test the machine before you buy it.
Reply:Yes test the welder and the generator before buying!!! The welding generator is separate from the power generator. I made the mistake of running a grinder when I got mine for 1500.00. I didn't weld with it because he didn't have leads( how convenient for him) it needed both boards changed. Cost me another thousand. Now it needs the front board again. It only has 179 hours on it. It currently will weld 3/32 and 1/8 with no problem but nothing bigger. Generator still at full power though.Miller trailblazer301gLincoln sa200Miller251Miller spectrum 625Victor oxy-acc2002 Chevy duramax 3500 dually 4x4
Reply:I've never looked at the circuit boards on a 301, but I would be willing to bet they just have generic components that can be easily replaced.  Probably $50 total in electronic parts on the boards.  Don't throw your old boards away if you end up replacing them.Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:If you can fix this one, it is yours......Sent from my HTCONE using Tapatalk Attached ImagesDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Yeah it is sitting on the exciter of my SA200 Sent from my HTCONE using TapatalkDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Well guys as my luck would have it with my bipolar family, dad changed his mind about it cause apparently my 3.4 GPA isn't good enough to get an engine driveSent from my C811 4G using Tapatalk
Reply:They only did that because they know your full potential, and somewhere you are slipping. You will thank them one day. Amazing how life goes, maybe they'll surprise you with a bran new vantage 500 one day.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Doubt it. Ill just suck and buy a new one after I get a good diesel rig setupSent from my C811 4G using Tapatalk
Reply:Originally Posted by weldermikeThey only did that because they know your full potential, and somewhere you are slipping. You will thank them one day. Amazing how life goes, maybe they'll surprise you with a bran new vantage 500 one day.
GMT+8, 2025-12-27 11:29 , Processed in 0.074350 second(s), 18 queries .
