1st project- a welding cart
发表于 2021-8-31 23:21:41 | 显示全部楼层 |阅读模式
I took a welding class and had so much fun, I bought a welder. I figured for my 1st project, I should make a cart. So here it is.
Reply:Very cool. Nice machine to.Making as much progress as a one legged duck in the middle of a pond, just going in circles.
Reply:Nice looking cart dude.  Good job! Sent from my GT-I9100 using Tapatalk 2
Reply:That's a nice looking cart man, looks quite sturdy and balanced. First time to see gas tank cylinders sitting beside the welder, usually most cart I see, tanks are behind the welder, LOLLove to your new machine bro, someday I'll be able to afford and  buy one like that, that's a very good and lasting welder. Well man enjoy your welding projects in the coming days.
Reply:Nice clean job.  Which paint and color code?TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Great looking cart, I really like that Blue.  What color is that? Rattle can or powdercoat?---No good deed goes unpunished---
Reply:Originally Posted by mebuilditGreat looking cart, I really like that Blue.  What color is that? Rattle can or powdercoat?
Reply:You took A class ..... as in 1 (one) class.... and built that.....You must be a savant......Nice work.......Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:I like the tanks on the side... Less of a reach for turning tanks on and off.  Also means you can switch out your tanks without pulling the cart away from the wall.
Reply:Sweet cart.  I like the contrast of the black mats, and the blue blues.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Orange (KTM) Bikes and Blue welders...nice combination. I ride Green Bikes and use Blue and Red welders. Nice cart.
GMT+8, 2025-12-27 12:52 , Processed in 0.115796 second(s), 18 queries .
