tig amps
发表于 2021-8-31 23:21:36 | 显示全部楼层 |阅读模式
Just for personal  knowledge and because of a potential project in the future.  What amperage should be used on inside corner joints, tig welding steel. All my tig welds that I've done have been flat butt joints.  1 amp per .001 inch has always been a good starting point.  I've tried a couple inside joints but haven't had the greatest luck.
Reply:http://www.millerwelds.com/resources...calculator.phpPost pics of weld and give all information on settings - someone here will be able to help you find the problem.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I think the problem was probably amperage too low and machine I was using
GMT+8, 2025-12-27 12:52 , Processed in 0.162238 second(s), 18 queries .
