A simple book shelf made out of 3/4" and 5/8" sq tubes (10"x24"x30"). Design is a industrial look. The outside is grinded with 120grit and the inside mostly untouched including the heat tints.Painted with acrylic clear coat.All welded with MM211, 0.035", 3 on the Voltage dial, 30 on the wire Speed dial.Shelfs are 20g sheet, bended with the HF 30" bender:Shelfs are tacked from the inside to the frame.Thanks for looking!
Reply:I welded two bolts the base of that bender, drilled two holes and bolt that thing down when I bend stuff.. a lot easier then clamps.. Nice shelf btw.www.thefusionsolution.com
Reply:Very nice work. I like it.
Reply:Nice work... and photography too.........Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:Thanks for your comments!The HF bender is not that bad. The bend has quite some radius for a 20g sheet, but thats OK for this purpose. The shelfs are 2' wide and needed support in the middle during the bend. Otherwise the bend radius of the middle section would be ever larger.
Reply:Neat and clean looking. Nice job.(Retired) Professional firefighter, amateur everything else I try to do...Oh yeah: Go Big Red! (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
Reply:Nice work. Looks clean, sturdy should last a lifetime.
Reply:Hey Jürgen, nice book shelf. Love the finish. I'm currently working on a book shelf as well, so i gotta ask, are there any supports under the 20g sheet?
Reply:Originally Posted by oxy moronHey Jürgen, nice book shelf. Love the finish. I'm currently working on a book shelf as well, so i gotta ask, are there any supports under the 20g sheet?
Reply:have you load it up with books yet? I'd be interested to see how your design workedthe book shelf i'm building is 78" wide, and with no center support. When I loaded it with books, it would sag about 1/2" at the center. I considered a design similar to yours, I think it would require 1/8" plate. With 8 shelves, it would probably make my floor collapse
Reply:looks real nice
Reply:Very Nice, and I know it wasn't simple you son of a gun! Simple is cinderblock and plywood!!! Nice work bud I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Would you mind posting a link to the product you are using? I use some from Home Depot and I cannot get in the corners well at all. Thanks.
Reply:Originally Posted by FexalNice work... and photography too.........
Reply:Originally Posted by 03protegeWould you mind posting a link to the product you are using? I use some from Home Depot and I cannot get in the corners well at all. Thanks. |
