Bondng Rubber To Metal
发表于 2021-8-31 23:21:30 | 显示全部楼层 |阅读模式
I've got a job that requires rubber pads to be bonded to steel plates. The plates are 4x4 H.R.S.What is the best adhesive/epoxy that I could use to get a good bond?Thanks,  AlA man is judged by what's between his legs...always ride a good horseMiller DialArc HFLincoln Classic 300DThermal Arc 181iPowermax 45Scotchman Ironworker(2) BridgeportsOkomota Surface GrinderAutoCAD 2010
Reply:http://www.gorillatough.com/And FOLLOW THE DIRECTIONS!!!It will never come apart if you do....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:3-M weather strip adhesive. We call it monkey jizz at work will bond damn near anything
Reply:I use this stuff for bonding neoprene to an aluminum part that I build for rigging.By far the best adhesive I've used for anything like this. It comes in a cartridge that is in two parts and gets automatically mixed in the nozzle. It uses a standard caulking gun to apply.http://www.mcmaster.com/#7646A12http://all-a-cart.comWelding Cart Kits and accessories
Reply:Prism 410 by Loctite. Properly applied, you will never pull the rubber off. It's what we used bonding rubber pads onto our ground support equipment where it interfaced flight hardware. Attached ImagesMiller Thunderbolt AC/DC (Sold)Miller Dialarc 250HFMiller MM251Miller MM200 (Sold)Miller MM130Miller Spot WelderVictor O/A rigMiller Spoolmatic 1 (Sold)
Reply:Originally Posted by tig dummy3-M weather strip adhesive. We call it monkey jizz at work will bond damn near anything
Reply:Not really glue but I have used this stuff for tons of stuff actually replacing welding in some applications:http://www.mcmaster.com/#fastening-t...-sides/=iaedleThe ones I used a lot were 4905, and 4910. This is not the same as the home depot double sided stuff competely different.For your application I would use 4952.If you take a couple of 1" x 12 pieces of aluminum, properly apply the above, let it sit 1/2 to 1 hour, and try to take it apart you will damage the metal before you break the bond, its tough stuff.These work best with close celled or medium celled rubbers. If your working with open celled rubber ( spongy ) ZT Fab gave you the right scoop. Hot glue is another option but you need to know which one your using, as these vary widely between types, and usually you need to buy a case which is probably not practical for you.
GMT+8, 2025-12-27 11:10 , Processed in 0.236640 second(s), 18 queries .
