Weather guard Pack Rat 336-3 Drawer Unit under Miller 250 NT
发表于 2021-8-31 23:21:30 | 显示全部楼层 |阅读模式
This is a Weather guard Pack Rat 336-3 Drawer Unit; found on Craig's List today. Want to mount in under my Miller 250 NT. Any suggestions or pit falls. Extra eyes looking at a problem are always welcome. Attached Images
Reply:I've got two of those pack rats. They are heavy duty SOBs. Takes two people to lift one of them. You can buy small parts as needed from Weatherguard as needed to keep it opening and gliding like new. Ive not looked close but it would not suprise me if they were made from .120 plate.The bobcat is probably 500 pounds. I'm sure the PR would probably take the weight but i would not do it out of fear what would happen in an accident. Even with bolts and mounting plates, that high center of gravity is asking for trouble for you and those around you.
Reply:Don't you know cats eat rats? It's obviously the perfect size and I wouldn't hesitate to do it.  The 14ga material of the PR is as strong as any utility box that Bobcats, Trailblazers, Rangers, etc find themselves bolted to.  I would use re-enforcement plates on the underside of the PR and in the mounting pockets of the Bobcat just the same and spacers to keep the Bobcat off the surface of the Pack Rat.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-27 11:11 , Processed in 0.076306 second(s), 18 queries .
