Quicky fire pit for Last night
发表于 2021-8-31 23:21:30 | 显示全部楼层 |阅读模式
Used my $200 Chinese Cut50DX plasma cutter to make this out of an old air compressor tank. Worked well! Attached Images
Reply:Falling onto that looks fun. Even unlit.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Do you fall often?
Reply:Bonfires and beer frequently go together...Seems a sad waste of a compressor tank.  A cheap old barrel would do just as nicely.
Reply:Heya Sample, I like it!  Would be a good size if you wanted to move it around you could do it without breaking your back.
Reply:Happy to hear it got you thru the nite (4th) after all that rain.  WHEELS are always helpful.  Then a handle.  Then BBQ Black paint.Then red orange & yellow like SWells:  http://weldingweb.com/vbb/showthread.php...ghlight=flames... your back yard looks about as happy as mine!
Reply:Originally Posted by anickodeBonfires and beer frequently go together...Seems a sad waste of a compressor tank.  A cheap old barrel would do just as nicely.
Reply:Looks niceDave ReberWadsworth Ohio
GMT+8, 2025-12-27 12:52 , Processed in 0.144844 second(s), 18 queries .
