Another Welding Bench
发表于 2021-8-31 23:21:29 | 显示全部楼层 |阅读模式
Hey guys i thought i show you my welding bench im working onThese benches used to be really long till i had a friend cut them down for me and mig them back up to 2 smaller ones.2 BenchesThen i decided to keep the best one and sell the other so i got it put up on top of the other one so i could give it a quick grind and hit it with kill rust paintPainted
Reply:Also bought a mild steel sheet for the topSo plan is to cut down the mild steel sheet and leave roughly a 50mm over hang so i have  some clamping room as wellWill post more pics tommoro
Reply:It'll be okay for a very, very light duty table.  Top is way to thin for anything except very light clamping and no hammer work.
Reply:lol it will do the trick for what i want it for
Reply:Not bad, but you might want to go back to the drawing board.I would change the way you mounted some of the angle on the bottom spanners - put the angle iron flat against flat and you get more strength, or place it inside the lower frame.Also, it looks like you could spend a little more time jigging up your corners. Definatly going to have a strain put on them if you put a lot of weight on the table.I break things for a living...
Reply:lol i bought them both like this, was a easy solution then doing one up my self which i will probally do one daylol my work isnt that shocking or messy at all, they were cheap enough lol
Reply:Double post sorryLast edited by frd906; 07-08-2012 at 06:20 AM.
Reply:I have decided to put a 12 mm ply sheet on to this table instead and will instead use the sheet steel i have cut for this table i will build a new table.reason why i am doing this is the top of this table is not dead flat so it will just be easier to build a newywill finish this one off once i got the ply wood cut for itcheers
GMT+8, 2025-12-27 12:43 , Processed in 0.101150 second(s), 18 queries .
