HTP Gas Fitting 90°
发表于 2021-8-31 16:58:40 | 显示全部楼层 |阅读模式
Does anyone know where to find a gas fitting that is 90° on this invertig 221 htp? I am waiting to put the cover over the machine without having to fight it over the gas in line and looking for "1/4" BS fitting"s are not getting me the correct fitting type. I found one on ebay but it's only got a inverted cone inside of it so it has no sealing abilities for this machine. Here is kind of what I am looking for but this one DOES NOT WORK: https://www.ebay.com/itm/1-4-6mm-Bar...e-b3cdab1c4d21
Reply:Originally Posted by jesusdayDoes anyone know where to find a gas fitting that is 90° on this invertig 221 htp? I am waiting to put the cover over the machine without having to fight it over the gas in line .
Reply:Seems unless the cover has slot the hose sticking out the back would interfere with the cover going on over it easily. We are talking about vinyl protective covers not the machine cover itself. Correct ? This is the typical 90° for inert gases. https://simsupply.com/departments/b2...%7C%20%2410.45Last edited by danielplace; 10-04-2020 at 02:27 PM.
Reply:Originally Posted by danielplaceSeems unless the cover has slot the hose sticking out the back would interfere with the cover going on over it easily. We are talking about vinyl protective covers not the machine cover itself. Correct ?
Reply:We are talking about the vinyl cover. If you didnt mind velcroing It every time it wouldnt matter, but I am looking to drop it on and pull it off John. This is because it is up high and back in a corner. Danielplace, that looks like it but I am thinking that male cone would need to have a female swivel threaded nut on there instead of that male threaded one...
Reply:Originally Posted by jesusdayWe are talking about the vinyl cover. If you didnt mind velcroing It every time it wouldnt matter, but I am looking to drop it on and pull it off John. This is because it is up high and back in a corner. Danielplace, that looks like it but I am thinking that male cone would need to have a female swivel threaded nut on there instead of that male threaded one...
Reply:Originally Posted by jesusdayWe are talking about the vinyl cover. If you didnt mind velcroing It every time it wouldnt matter, but I am looking to drop it on and pull it off John. This is because it is up high and back in a corner. ..
Reply:My cover is from 2013 so it doesn't have velcro anything.  I have to disconnect the gas line when I put the cover on. This other cover must be a lot newer. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:danielplace, since you found that fitting for me, I'm going to get it and see if that joint is just soldered together. If it is, I got another fitting that I can drill the swivel nut off of and I'll try putting it on your fitting to make it work.Wish I could post pictures on this to save you guys some time looking things up.
Reply:Here is the backside of my cover. It does what it supposed to do.... Cover the machine. I ‘guess’if you really wanted to nitpick,You could pull it down maybe another quarter inch.... but not enough to make a big deal about.  And even if you did, It would only require is a small slit with a razor knife.  Much to do about nothing if you ask meYeah I know you didn’t ask.  .Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:FOUND ONE!!!!!They are calling it a "Flowfit BSP 90° Swivel Female Hydraulic Hose Fitting" on ebay. Get the 1/4" BSPP 90° version. It ships from the UK but was not very long at all.https://www.ebay.com/itm/Flowfit-BSP...72.m2749.l2649Just keep the velcro loose and toss the cover on and off. Seems to be working well so far.
GMT+8, 2025-12-18 16:18 , Processed in 0.070237 second(s), 18 queries .
