Polishing Stainless Steel
发表于 2021-8-31 23:21:21 | 显示全部楼层 |阅读模式
Whats the difference between polishing with sanding belt/Scotch Brite and polishing with cotton wheel that you fill with the red clear "jelly" and then fill with the abrasive paste ? And what's called the second method mentioned ? Im pretty sure there's a name for each method difference ? I know you can do a mirror finnish with the cotton wheel and some compounds, but when you have to make a #4 finnish (brushed) what's the difference with both method ? To me its sounds easier to work with Sotch Brite or sanding belt.
Reply:This has some interesting reading. http://www.caswellplating.com/buffs/images/Buffbook.pdf
Reply:Thats a good PDF thanks a lot!I know how to search on google haha, i was just having problems because i didn't know how this was called!Thanks
Reply:Originally Posted by LayoutManThats a good PDF thanks a lot!I know how to search on google haha, i was just having problems because i didn't know how this was called!Thanks
GMT+8, 2025-12-27 11:30 , Processed in 0.126536 second(s), 18 queries .
