Lifan AXQ1-190 welder generator
发表于 2021-8-31 23:21:19 | 显示全部楼层 |阅读模式
I bought this welder generator a couple years ago at an auction for $200.00 dollars in a non running condition.  The only thing wrong was some carburetor problems after fixing those it runs great and I have used it numerous times around the farm and it worked fine as a small generator and a welder.  I had a power outage and was using it to power the blower on my wood furnace.  I left for a half an hour to go get some more fuel when I returned it had quit producing power.  I checked to see if it would strike an arc and no luck.  I have checked anything that looked like a fuse and pulled the brushes out everything looks and checks out.  I can't figure out or know what to check.  I have definitely got my moneys worth and know it is Chinese but it does run good and I hate to just throw things away if they can be fixed.  Just need some direction on what might go wrong while it is running and how to test it.  I have heard about exciting the brushes but this machine was running and working so I don't believe that is the issue.  Thanks for any help.
Reply:Save yourself the headache of trying to fix it, finding parts for lifan(which is Chinese harbor freight) will be troublesome to say the least.
Reply:Lifan engines are made in Thailand I think. Not sure where they get their generator assemblies.  Can't be too complicated.  Slip rings, brushes, switch connections, maybe internal breakers or fuses?Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
GMT+8, 2025-12-27 11:28 , Processed in 0.077840 second(s), 18 queries .
