Welder blowing up
发表于 2021-8-31 23:21:19 | 显示全部楼层 |阅读模式
Hi today I was welding a 3G open root weld and I turned my welder on and did the first pass then when I did my second pass my welder just went bang I turned it off then turned it on and it buzzed loud then soft and I turned it off and when i turned it on again it sounded normal I let it run for a minute and nothing happend. Would I be safe to weld with it again.1 270 wia weldmatic mig welder1 Abel arc welder1 188 bossweld arc and tig welder1 cigweld comet o/a set
Reply:No.  Magic smoke has been released.  The genie is loose and must be returned.Miller Dynasty 200DXMiller Spectrum 250DMiller Millermatic 200Bunch of old blue dinosaurs....
Reply:Originally Posted by OxymanHi today I was welding a 3G open root weld and I turned my welder on and did the first pass then when I did my second pass my welder just went bang I turned it off then turned it on and it buzzed loud then soft and I turned it off and when i turned it on again it sounded normal I let it run for a minute and nothing happend. Would I be safe to weld with it again.
Reply:I would at least open up your welder and see if you can see what made the bang.  I can't say I've ever heard a welder bang.
Reply:The capacitors used in DC welders can sometimes go bang. Sometimes diode rectifiers will also go bang when they go bad. In either case the evidence will be very visible when you take the cover off. Look for smoke trails and burn marks.CharleyMiller MM252Miller Bobcat 225NTMiller DialArc HF / DIY Cooler2 Victor O/A TorchsetsMilwaukee 8" Metal SawMilwaukee Dry Cut "Chop" Saw 5 Ton Wallace Gantry Various Grinders, Benders, etc.
Reply:Originally Posted by jontheturboguyNo.  Magic smoke has been released.  The genie is loose and must be returned.
Reply:engine drive or electric? i don't think you said. i've seen the panel box to the welder blow up but never the welder itself. as was stated above open er' up and look around.i.u.o.e. # 15queens, ny and sunny fla
Reply:That happened to me once on my first Trailblazer but there was no starting it back up. There was oil coming out of two cracks in the case. I think it had over 11,000 hours on it at the time.
Reply:I guess you could look at the bright side.  Good excuse to go buy that new welder your been eyeing for sometime now.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Originally Posted by pigeonpoopOpen it up and get familiar with it like you did your first wife.
Reply:It's a electric welder on ac
Reply:To answer your original question.....Yes, you yourself should be safe to attempt to weld with it as long as you follow typical welding electrical precautions.Ensure welder electrical line-in is properly sized, configured and grounded all the way back to electrical panel.Have air gap between welder metal case and welding table or work piece.Establish clean/solid/tight electrode ground thru work clamp to work piece itself, not the table alone.Wear rubber soled shoes on dry floor and appropriate gloves and PPE.What you experienced might be as simple as you exceed the welders duty cycle and it pooped the bed....Or it might have develop a high resistance connection that finally arced and sparked.Suit up and go for it ...If it's broke, you won't break it no more than it already is, but take care not to break you.
Reply:If you want better answers you are going to have to tell us the make and model of the welder, what welder settings you were using, etc. We can't see it or you unless you tell us more and post pictures if you can. Then we might be able to help you.CharleyMiller MM252Miller Bobcat 225NTMiller DialArc HF / DIY Cooler2 Victor O/A TorchsetsMilwaukee 8" Metal SawMilwaukee Dry Cut "Chop" Saw 5 Ton Wallace Gantry Various Grinders, Benders, etc.
Reply:It welds but it makes smoke when you weld with it
Reply:Have you found out the brand and model of welder yet?
Reply:I popped an xmt 350 once, pretty noticeable bang, but it didn't weld after that. . . . I wouldn't do anything with it until you take the cover off and assess damage, at leastbosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:Originally Posted by OxymanIt welds but it makes smoke when you weld with it
GMT+8, 2025-12-27 11:28 , Processed in 0.101903 second(s), 18 queries .
