Thickness vs rod size
发表于 2021-8-31 23:21:16 | 显示全部楼层 |阅读模式
What is the recommended  thickness for using 1/8 7018
Reply:For me, minimum 3/16""Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Same here.
Reply:FlyingJ - good rule of thumb is to not weld metal thinner than the rod.A little thicker, like said above, is easier Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Thanks I was making a welding table with 1/8 7018 n I was using like 1/8 I beam either looks cold or droop out on vertical up
Reply:Remember with stick welding you base your amperage off of the rod size. One amp per thousandt of an inch. Or if you wanna do some math just turn the fraction into decimals. Like 1/8 into decimal form is: 0.125. So your amperage should be somewhere in that ball park for 1/8 rod. 125 amps
Reply:Originally Posted by FlyingJThanks I was making a welding table with 1/8 7018 n I was using like 1/8 I beam either looks cold or droop out on vertical up
Reply:So if im welding 1/8" steel with 1/8" rod its set at 125amps. Interesting.Fireman BillHH 210 MVPMM 211 Spoolmate 100Lotas LTP5000D PlasmaOxy/Accet (Victor)Wards AC/DC buzz box30 ton old hyd pressA few brand name toolsA bunch of cheap toolsA wife to worry me and4 dogs to supervise me
Reply:Originally Posted by Fireman BillSo if im welding 1/8" steel with 1/8" rod its set at 125amps. Interesting.
Reply:Here's Miller's Stick Welding Calculator. http://www.millerwelds.com/resources...calculator.phpAlways weld on a scrap piece of same size and material to set heat. Every machine is a little different. You can start at 125 and find out it's way too hot or cold . Go up or down accordingly. Numbers are only a starting point. 125 amps on a MILLER might feel the same when it's 150 on a Lincoln. Some guys like a hot machine and can handle it.
GMT+8, 2025-12-27 11:28 , Processed in 0.405264 second(s), 18 queries .
