C3 x 1.5 channel for welding table frame?
发表于 2021-8-31 23:21:16 | 显示全部楼层 |阅读模式
I am looking at used C3 x 1.5 pallet rack for my table's frame.  I was previously looking at 4x4 x 0.250" or larger angle iron.  The C3 is a fair deal cheaper.  Although both are about 1/4" thick, it looks like the moment of inertia of the C3 channel is about half of the 4" channel - so the frame will be more prone to flex under load.  The frame will be around 105" L x 48" W.  Should I pony up for a 4" frame?   Table top is 5/8" thick and will generally be used for light-duty tasks but would like to be able to occasionally use it to hold a tractor FEL & Bucket, bush-hog, or other large/heavy objects.Thanks
Reply:I've never been mad after making something too big/strong. Making it too small/weak on the other hand....
Reply:Is there big $$$$ difference in cost ??  Your only gonna do it once right ?  Heavier is better. If you want lighter just buy one. That's the beauty of building your own, it will be heavy and hold anything you can chain fall on to it.
Reply:Originally Posted by BD1Is there big $$$$ difference in cost ??  Your only gonna do it once right ?  Heavier is better. If you want lighter just buy one. That's the beauty of building your own, it will be heavy and hold anything you can chain fall on to it.
Reply:You will forget about how much you spent way before you stop worrying about putting something heavy on it.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Originally Posted by GravelYou will forget about how much you spent way before you stop worrying about putting something heavy on it.
Reply:I understand the allure of getting something cheap, but considering the size and weight of your table and its intended use, bigger is definitely better. Also, the height of the web has a greater effect on strength than the thickness. Doubling up two 3" channels will still not have the load-bearing strength of 4" angle.You could compromise and make the outer frame and legs from 4 x 4 x 1/4" angle and use the C3 for bracing the short (48") way under the table top.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:Originally Posted by Silicon-basedthe height of the web has a greater effect on strength than the thickness. Doubling up two 3" channels will still not have the load-bearing strength of 4" angle.
GMT+8, 2025-12-27 11:28 , Processed in 0.076061 second(s), 18 queries .
