Which Victor torch handle are these tips for?
发表于 2021-8-31 23:21:07 | 显示全部楼层 |阅读模式
Hi All,    Just a quick question that I can't seem to find the answer for online - which Victor torch handle are these tips for (picked them up at an auction)?  They're all welding tips and have a size, X, and then T13 (eg, 1-T13).  One has the size, 3, and then Type 13 (3-Type13).  They are too small to fit on my 315 handle, but I'm not sure if they fit on a 100-series handle or the "J" handle.Thank you!Jon
Reply:What is the ID of the nut which holds the tips onto the handle? My J handle's threads measure .557", probably 9/16" whereas my 100's handle measures .622", probably 5/8".metalmagpie
Reply:I dug out my old Victor book. The 1-T-13 will fit your 100 series handle, while the 3-T-13 will fit your J series handle.
Reply:Thanks for the responses. What I'm finding online is that all the T-13 (type 13) tips are equivalent to the W-1 tips, which fit the 100 series handles.  For the J series handles I'm seeing that the W-J equivalent is T-17 (type 17).  These seems to make sense - the 1-T-13 and 3-T-13 tips have the same size base and nut.The site I found the info on eventually was:  http://www.gossonline.com/site/Victor_Tips.phpThanks!Jon
Reply:I just picked up a couple of Victor tips from eBay for $36 shipped: a 3-W-1 & a 6-T13.  Based on the above & on the Goss Web site it looks like the 6-T13 is equivalent to the 6-W-1 tip & will fit my FC100 handle.  Maybe an old model number?I measured the ID of the nuts that holds the tips onto the handle & they were both about 0.577", but I used calipers I had handy so the measurement is pretty rough.Thanks for the info!
GMT+8, 2025-12-27 11:28 , Processed in 0.102513 second(s), 18 queries .
