scratch start tig
发表于 2021-8-31 23:21:06 | 显示全部楼层 |阅读模式
i got almost everything i need to put together a scratch start tig sit up on the ideal arc or stickmate. i was looking for tips on doing this ive never even tig welded. what kinda tungstens should i get? what size? reminder i know very basic stuff about tig welding been watching youtube videos like crazy. any help is good help2-Lincoln idealarc 250/250, lincoln 225 ac/dc welder, lincweld ac 180c, hobart handler 210, hobart stickmate lx 235/160, Hypertherm Powermax30local 26 I.B.E.W Electrician
Reply:The size and type of tungsten depends on the amperage range and materials (and even torch) you plan on using. Need more info.Welding/Fab Pics: www.UtahWeld.com
Reply:i prefer red or gold band tungsten though. For scratch start, just make sure you have that SHARP, you want it needle sharp it will make starting the arc so much easier on you. If you keep it sharp and clean you should barely have to touch the tungsten to the work to get the arc going.ESAB MigMaster 275Miller Econotwin HFMiller Syncrowave 250
Reply:the torch is rated to 150 amps that about the max i would do. i would be using this for thin stuff also like maybe 1/8 inch if i could2-Lincoln idealarc 250/250, lincoln 225 ac/dc welder, lincweld ac 180c, hobart handler 210, hobart stickmate lx 235/160, Hypertherm Powermax30local 26 I.B.E.W Electrician
Reply:i like using 3/32 tungsten and 2%thori( red )is all i useidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Same here. I use 3/32 red (2% thoriated) tungsten for all my scratch start tig welding.I use a 150 amp ck workdwide air cooled torch and rarely tig weld anything over 75 amps with it.Last edited by snoeproe; 11-29-2011 at 09:34 PM.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2025-12-27 11:29 , Processed in 0.113043 second(s), 18 queries .
