Harris torch question
发表于 2021-8-31 23:21:03 | 显示全部楼层 |阅读模式
I am working with 18 gauge steel.  I have a Harris torch with #0 tip.  I have my Acetylene set a 5 PSI and the Oxygen is set at 5 PSI as well.  When I try to set a neutral flame the adjustment on the oxygen is extremely minute.  It seems like every time I try to make the adjustment it blows out the flame and I have to start all over.  This is a hobby set with the smaller hobby tanks.  Once I get everything set, it is perfect for the sheet metal.
Reply:Your acetylene is too high. Try it around 3; oxygen around 10.
Reply:Thanks, I will give those settings a try.
GMT+8, 2025-12-27 11:30 , Processed in 0.097817 second(s), 18 queries .
